wiring temp sensor to mirror
Ok i got an autodim mirror from an intrigue GLS. My question is how do i wire the temp sensor to the mirror? Do i need something else to make it work? Any help would be appreciated. Thanks
need a temp sensor from that car also. when i did my tgp i mounted the sensor on the support in front of the radiator. try and get some of the wiring also or at least connectors with a little wire and set it up similiar to the car you got the mirror from.
well i have to sensor i just need to know how i would hook it up to the mirror.
Are you sure it actually displays temp (since the ECC did it, and the mirror would be redundant)? My GLS mirror only does the compass.
mine displays both, i got the sensor from the front bumper around the air dam, and the mirror has degrees Fahrenheit or Celsius.
I know the display inside the mirror has the provisions on the LCD, but are you SURE they actually function in this particular model?
Like I said, it has the sensor in the air dam for the ECC.
you know what i think your right. :redface: I forgot that the ecc has the outside temp.
It happens :lol: I thought the same thing when I got mine.
need to get wiring schematic to see what wires go where. mine that i put on my tgp was very simple but i have a sunroof and my new mirror doesn't have the lights on the bottom of the mirror.
I've figured out how to wire it, but now i have to figure out the wires on the original mirror. There were 3 wires red black and white. Does anyone know what those wires are?
