oldscsc Posted January 2, 2009 Report Posted January 2, 2009 this is a perfect opportunity to shave the antenna, it will clean the rear end up nicely I'd rather have reception than a "clean" rear end. IMO of course. Quote
jake91 Posted January 2, 2009 Author Report Posted January 2, 2009 x2 but it would look nice though Quote
mra32 Posted January 2, 2009 Report Posted January 2, 2009 this is a perfect opportunity to shave the antenna, it will clean the rear end up nicely I'd rather have reception than a "clean" rear end. IMO of course. ask slick about what other kind of antennas you can get. I think there are ones that can sit in/on the rear window on the inside and some work fairly well. Quote
slick Posted January 2, 2009 Report Posted January 2, 2009 Yeah, there is an antenna that sits inside at the top of the window. Held on by double sided tape, and is powered (supposidly gets a bit better reception from the few people that I know that have used it). IIRC, they aren't expensive either. Quote
jeremy Posted January 3, 2009 Report Posted January 3, 2009 this is a perfect opportunity to shave the antenna, it will clean the rear end up nicely I'd rather have reception than a "clean" rear end. IMO of course. enlighten me as to why shaving the antenna would give you no reception..... Quote
oldscsc Posted January 3, 2009 Report Posted January 3, 2009 this is a perfect opportunity to shave the antenna, it will clean the rear end up nicely I'd rather have reception than a "clean" rear end. IMO of course. enlighten me as to why shaving the antenna would give you no reception..... No antenna means decreased reception. That is what I'm trying to avoid as I listen to radio stations based out of town on a regular basis. Quote
jeremy Posted January 3, 2009 Report Posted January 3, 2009 who said anything about no antenna? I said shave the antenna, which typically involves mounting the antenna mast inside a fender, trunklid, etc....reception typically isn't effected very much, if at all.... let me try to dig up a pic of two of when I did this to one of my old Probes Quote
jeremy Posted January 3, 2009 Report Posted January 3, 2009 here are two pics that I could find....these show the mast mounted on the inside of the rear hatch/trunk area. this pic is from a fiero, showing mounting the mast inside the front fender Quote
oldscsc Posted January 3, 2009 Report Posted January 3, 2009 I've heard about doing that before, I was thinking you meant antenna delete. Sorry for the confusion. Quote
jake91 Posted January 3, 2009 Author Report Posted January 3, 2009 i would love to do something like this, and i would if i knew how to do body work Quote
Crazy K Posted January 3, 2009 Report Posted January 3, 2009 I intend to do something different. I would add a hidden antenna and leave a power antenna in the down postion and disconnected. I also would have it setup so I can re-enable to power antenna with a switch, and be able to manually switch which antenna I would use. SLICK any links on info about the antenna you mentioned? Quote
xtremerevolution Posted January 3, 2009 Report Posted January 3, 2009 I used to have a power antenna. Then I didn't want to go down anymore. One day I went through a touch car wash. Now I don't have an antenna anymore. Quote
rockfangd Posted January 4, 2009 Report Posted January 4, 2009 I like thwe concept of the old fords like the crown vic with the antenna button for up or down Quote
ManicMechanic Posted January 4, 2009 Report Posted January 4, 2009 I intend to do something different. I would add a hidden antenna and leave a power antenna in the down postion and disconnected. I also would have it setup so I can re-enable to power antenna with a switch, and be able to manually switch which antenna I would use. Whyyyyyy? I will probably just upgrade the antenna in the Blazer to a 1994+ one... The van does not have an external antenna...It is IN the roof. Doesn't do too bad either. Quote
jake91 Posted January 4, 2009 Author Report Posted January 4, 2009 I like thwe concept of the old fords like the crown vic with the antenna button for up or down i loved it. my moms old mercury cougar had that Quote
Crazy K Posted January 4, 2009 Report Posted January 4, 2009 The van does not have an external antenna...It is IN the roof. Doesn't do too bad either. Yes, but your roof is fiberglass! I saw one of those... it is a giant "gold foil" sheet, with a divisional "0" in the middle, so it looks to be a two part antenna sheet. Quote
digitaloutsider Posted January 4, 2009 Report Posted January 4, 2009 I intend to do something different. I would add a hidden antenna and leave a power antenna in the down postion and disconnected. I also would have it setup so I can re-enable to power antenna with a switch, and be able to manually switch which antenna I would use. SLICK any links on info about the antenna you mentioned? This is the stupidest idea you've ever had Quote
Crazy K Posted January 5, 2009 Report Posted January 5, 2009 This is the stupidest idea you've ever had Not really. I'd just like to not have to do any body work. It would be different on a car like my 94 black car, which will need a complete re-paint to sell. Quote
slick Posted January 5, 2009 Report Posted January 5, 2009 I intend to do something different. I would add a hidden antenna and leave a power antenna in the down postion and disconnected. I also would have it setup so I can re-enable to power antenna with a switch, and be able to manually switch which antenna I would use. SLICK any links on info about the antenna you mentioned? Your idea is pretty dumb. The one we used- http://www.scosche.com/products/sfID1/151/sfID2/154/sfID3/154/productID/1052 Similar Styled- http://cgi.ebay.com/ebaymotors/Universal-Am-Fm-Hidden-Windshield-Antenna-Car-Radio-New_W0QQitemZ110333945585QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item110333945585&_trksid=p4506.c0.m245&_trkparms=72%3A727%7C65%3A12%7C39%3A1%7C240%3A1318 Quote
