Having a Cooling System FLUSH done...
Tomorrow morning...I've owned the car for 3.5 years and never had it flushed, so I figure it's over-due...
I was just curious as to whether there's anything else I should do, ask, look out for etc...
Should I tell them to replace the Radiator Pressure Cap? Or just check it?
THANKS!:)
just a check if it is good no need to rplace it but if bad they will do it
they should tell you if it is bad if not ask if they did the test
it should come with the flush i think?
good luck
p.s. if you think it should be done and no one says anything by all means ask!
THANKS!:)
Coolant should be changed every other year to prevent rotting of gaskets / hoses.
So, I am FOR doing a coolant flush.
But, if the radiator cap is not leaking, no need to replace.
- Erik
