digitaloutsider Posted December 28, 2008 Report Posted December 28, 2008 Okay, backstory: for the last month or so, the car has been acting quirky, but I've just chalked it up to a bad PCM tune and the back that it's a hobbled together mess of a car. Basically, every time I hit about 35-40 MPH or so, the TC would engage and the car had a slight shake and increase in RPMs, but again, I attributed this all to a bad tune. Tonight I figure I'll go out and actually retune the car with a basic DHP 1.5 bin file and see where that got me. Dump the file and try to start the car.. nothing. Security light. No crank, PKII is stopping the pump. Okaaay.. makes no sense, but no big deal. I'll just go in HPTuners and repogram the VIN, VATS, etc. Reprogram was successful. Try to start the car again. Nothing. What the hell? Pull the battery for 30 minutes or so. Connect it and attempt to start the car. Nothing. Go into HPTuners, change the VATS signal to PWM and delete the related DTCs. Car starts, but we've got a security light. Again, makes no sense, but whatever. I go out to take the car for a drive. It started out driving fine, but the second the TQ engaged, it was a noticeable "bang". During decel, the car shudders violently. I figure the PCM must be toast. Drive 30 minutes out to BFE to pick up my spare PCM. Plug it in, reprogram. Hey! Starts right up! No security light, nothing! Pull it out of the driveway and start gradually going down the street. The moment the TC engages.. BANG. Same thing. Same shudder, but on the way home the pump starts whining something fierce. So... sounds like I've somehow successfully killed 4T65E-HD #3 in my car unless you guys have any ideas. Please say you do? Quote
98montels Posted December 28, 2008 Report Posted December 28, 2008 Sounds transmission related, instead of PCM related, but it could be something with a solenoid or something dumb like that. Quote
digitaloutsider Posted December 28, 2008 Author Report Posted December 28, 2008 Yeah, I was thinking possibly the torque converter clutch solenoid, but it doesn't explain the horrendous pump whine. Quote
98montels Posted December 28, 2008 Report Posted December 28, 2008 digitaloutsider said: Yeah, I was thinking possibly the torque converter clutch solenoid, but it doesn't explain the horrendous pump whine. True forgot about that. My transmission is noisy, I believe it a 4T60E it sounds at times like a power steering pump kinda. But it's on the wrong side of the motor for that and you can here it with the hood popped it's not loud but the TC or sumthin is loud in my monte. Note it has about 133xxx on it and the trans hasn't been touched since the assembly line. Quote
Pontiac6KSTEAWD Posted December 28, 2008 Report Posted December 28, 2008 Sounds like the TQ converter is dieing/dead to me.. Quote
White93z34 Posted December 28, 2008 Report Posted December 28, 2008 thing is that TQ is almost brand new has not even 10k on it! Quote
slick Posted December 28, 2008 Report Posted December 28, 2008 x2, with the way it shudders, I would say torque convertor as well. Does it even lock up, or not? And, if it locks up, and you accelerate slowly enough to keep it locked up while accelerating, do you have any shuddering? Quote
5speedz34 Posted December 28, 2008 Report Posted December 28, 2008 It sounds like god hates you...sorry to hear your luck dude. Quote
AL Posted December 28, 2008 Report Posted December 28, 2008 gpchris said: 6-speed swap? THATS IMPOSSIBLE!!! j/k Quote
1990lumina Posted December 28, 2008 Report Posted December 28, 2008 That sucks that the original tranny lasted so long, and then the other two have failed so quickly. When the torque coverter got bolted up to the flexplate did you use the correct length of bolts? At school the other group put together a Dodge drivetrain and put bolts that were a few mm too long and they distorted the inside of the torque coverter where the clutch mates up. It burned out the torque coverter clutch in a few thousand miles. Quote
Brian P Posted December 29, 2008 Report Posted December 29, 2008 what tune did that replacement PCM get? Still have the PWM solenoid modification set, or is it all stock? Silly question but regarding that pump whine.... fluid level's okay? Quote
White93z34 Posted December 29, 2008 Report Posted December 29, 2008 After a good bit of research and some driving it, we have come to the conclusion that the TQ clutch solenoid is bad, and once it engages the TQ it does NOT want to disengage. i'm sure shaun will chime in with more specifics. Quote
digitaloutsider Posted December 29, 2008 Author Report Posted December 29, 2008 I flashed to DHP's 1.5 bin file, which always ran great on the car before. Tried flashing back to my stock HPTuners file, which still isn't better. It's finally throwing the DTC for TCC solenoid stuck on. Quote
Brian P Posted December 29, 2008 Report Posted December 29, 2008 Shitty. I guess you could always chop the solenoid wire for the time being. Quote
slick Posted December 29, 2008 Report Posted December 29, 2008 Brain P said: Shitty. I guess you could always chop the solenoid wire for the time being. Karate chop? Quote
Brian P Posted December 29, 2008 Report Posted December 29, 2008 THAT is gay? You need to lurk the whatever thread occasionally Quote
5speedz34 Posted December 29, 2008 Report Posted December 29, 2008 Brain P said: THAT is gay? You need to lurk the whatever thread occasionally No shit. So the TCC solenoid is stuck open? Quote
digitaloutsider Posted December 29, 2008 Author Report Posted December 29, 2008 Yeep. Not releasing. I guess I'll go out there tomorrow and try to depin the wires from the PCM harness. Quote
5speedz34 Posted December 29, 2008 Report Posted December 29, 2008 digitaloutsider said: Yeep. Not releasing. I guess I'll go out there tomorrow and try to depin the wires from the PCM harness. Good luck bro. Quote
digitaloutsider Posted December 29, 2008 Author Report Posted December 29, 2008 Yeah, fuck it. That's it. The tranny is toast. Went out to try and drive it up to the gas station for a soda and to see if letting it sit had any effect on it. Nope. Put it into reverse. BANG. Put it into drive and we have no forward gears. Backed it up into the driveway and that's where she'll sit. End of 4T65E #3 and likely the end of this piece of shit car. Quote
Night Fury Posted December 29, 2008 Report Posted December 29, 2008 WOW. I am SO sorry! That sucks ASS. Quote
