bolt pattern
Okay, I've looked around the w-body.com page, and searched the board archives, but I'm still a little fuzzy on what the bolt pattern is for the '95 or so GTP 5 spokes.
Is the bolt pattern 5 - 115?
Is 25mm the offset?
Thanks!
Guest Anonymous
I'm pretty sure the offset was not 25mm. The TGP had the 25mm offset and those wheels won't work.
the stock wheels for a 1st gen W-Body (including the 1995-99 Monte's and cutlasses)
16x6.5 Rim Diameter/Width
5x115 Bolt pattern
38mm Offset
TGP crosslaced wheels are:
16x8 Rims Diameter/Width
5x115 Bolt pattern
25mm Offset
1997+ Grand Prix's, Impala, 2000+ Monte, Olds Intreuge, 1997+ Regals
5x115 Bolt pattern
52mm Offset
the 2nd gen w-body wheels will not fit without longer studs and a large spacer. I am currently working on getting a set of 2001 Monte SS High Sport Appearince wheels to work on my Lumina Z34.
The 16x8" Crosslaced TGP wheels WILL work on your 1st gen W-body. the 1995 GTP wheels will work as well again because they are also a 1st gen. they GP's didn't switch until 1997+.
Hope this helps,
RedZ
95 5-spokes have a +25mm offset as well. They are 16x7 wheels.
They only came on B4U (GP's with ground-effects and flares).
Well i learn something everyday.
RedZ
