3.1L with slight hesitation just off idle
I've got this '94 3.1L cutlass with a slight hesitation just off idle after the engine warms up. I've just done a complete tune up, upper intake gaskets, inspected vaccum lines, cleaned egr and iac sensors, the tps readings also look ok. does anyone have any ideas, thanks.
If only when warm, I'd start looking at the coils/ignition module. They can get heatsoaked and cause issues.
Any problems with upper rpm's when warm vs. cold?
no rpms are in normal range when hot and when cold. resistance through coils are very close to the same. as for the ign. module is there any way to check that?
When my injectors shit the bed this summer in the Lumina they caused a hesitation off idle - and eventually it got bad enoguh you could stall it.
