DeathScythe
How did you disconnect the main wiring harness that goes into the firewall on a 93 Lumina 3.1. It is the one on the passenger side next to the strut tower. Thanks AJ.
T30 torx from under the hood. I use a longer extension (8") push it is, tap it a few times to make sure it seats... then turn.
thanks because there is so much dirt in there that you can't see anything.
