Can't get bottom of air box installed
Ya this will sound dumb, but I'm having a problem get the bottom of the air box back in - its in a 96 GP LQ1, its the part where it seem to just push back on to the battery clamp - it looks like you just have to push, but can't seem too - should I just try harder or is there a trick to this...
bump - anyone... someone has to know the trick to getthing this back in the right spot...
I have a 94 GTP and on the box there is a rubber "nub" that goes into a hole by where the battery is located.(way near the bottom) Its a tight fit. THere is also a screw hold that goes on the battery holder (near top of battery. I hope this helps. Ill see if I can get a pic.
Dunno if this would be the same as on my Lumina but one of the coolant hoses is always in the way of getting the air box bottom out. I just tug the shit out of it and it'll come out...and shove the shit out of it to get it back in.
LuckoftheGTP - ya its the rubber nub - I'm talking about, can't get it back in
1990lumina - shove the shit... I've tried, I'll maybe try harder knowing its been hard for you guys aswell.
thanks for the help
If you can get the airbox all back together and in, I wouldn't worry about the nub.
The 94+ cars have this stupid extra bracket over the battery, it's such overkill.
Just shove HARDER, you really have to work to get it in there. Watch what hoses/pieces it hangs up on and try to work around em or push stuff out of the way.
