Just a thaught...
Would the Getrag 282 out of the W-Bodies happen to be the same Getrag 282 that is in some of the 3.1 Cavaliers???
I was talking to my buddy austin who has a 90 cavi with a Getrag 282 and the 3.1L
- Justin
otherwise though, one could theoretically bolt one right up???
- Justin
yep would mount right in....
same as in the grand am, Beretta, and corsicas too
and a local Junk yard here has all of them...but hes holding the one GP 5spd for me...
so how different are the ratios in the 2??? the W-Body 282 vs. the L-body 282. In theory, i should be able to pull one out of a retta or cavi and drop it right into my GP???
- Justin
also, is the power handling different??? can the L-Body 282s take more then the W-body???
what other issues would i have with this???
what about the chip??? I have the memcal out of a GP with a 282, would that work in my GP with the L-Body 282???
i also am getting that W-Bod 282 this friday or saturday for Malibuolds.
thanks for the help.
- Justin
Correct. They shouldn't be a problem.
To find ratios, I would search the Beretta.net site and ask around.
Also, check YOUR RPO code because that holds the ratio numbers.
If you finds another non-W-Body manual tranny with the same RPO, it'll be a direct swap; ratios and all.
- Erik
Go to brian89gp's website. It's got all the ratios for all the different versions of the 282
Robby
