Headlight Replacing
So I found out my driver side headlight went bad..My dad told me in this car I'll have to take out the battery to replace it. Is that true? And any quick hints or tricks? Kinda hard to work in 25° weather when you live in Oklahoma.
no. take the headlight covers off, and all you need to change the bulb is a T15 torx.
That and there is a little spring on the bottom of the light that you need to be careful in removing and installing so you don't accidentally drop it.
your dad sounds like a chiltons manual'
edit: reading > me. he said take out, not disconnect. whoops lol
Now that's funny...And true.
T10 isn't it?
Actually it's a regular torx. T10. Very easy to replace. Or you can use a 1/4 socket.
Are you talking about the adjusters or the actual bolts that hold the light in?
