Guest GrandPrixlover1 Posted December 7, 2008 Report Posted December 7, 2008 I went to Grismer for an Oil change yesterday, and they told me that I needed a new fuel filter. I want to check this myself...mainly to save money from having to go to a mechanic. I know to test a fuel filter you take it out and blow on it. I was just wondering how much resistance should there be as far as air being pushed through the filter, before it needs to be replaced? I mean a fuel filter at AZ is only 7 or 8 bucks but like they say..."if it aint broke, don't fix it". Thanks for any help guys. Quote
BXX Posted December 7, 2008 Report Posted December 7, 2008 Replace your fuel filter every 15-30K.. Its like an oil change, normal maintenance Quote
slick Posted December 7, 2008 Report Posted December 7, 2008 If your not sure how long it's been, then your well overdue. Quote
3pt1lumina Posted December 7, 2008 Report Posted December 7, 2008 When I changed my first fuel filter ever, I gained 5 mpg (was on my 90 Lumina) and I couldn't believe it. So now every 15k it gets done. So if you have no idea how old it is, it's cheap enough to do. It's just regular maintenance. I'd do it. Quote
Night Fury Posted December 7, 2008 Report Posted December 7, 2008 I bet the one om my CS is original! But I can't get it off! Quote
BXX Posted December 7, 2008 Report Posted December 7, 2008 I bet the one om my CS is original! But I can't get it off! Thats why it doesnt run correctly Quote
5speedz34 Posted December 7, 2008 Report Posted December 7, 2008 I need to change mine. Pretty much replace every 2 years. Quote
jeremy Posted December 7, 2008 Report Posted December 7, 2008 I need to change mine. Pretty much replace every 2 years. even when it hasn't moved in that time frame? Quote
5speedz34 Posted December 7, 2008 Report Posted December 7, 2008 I need to change mine. Pretty much replace every 2 years. even when it hasn't moved in that time frame? I'm talking about the Grand Prix. I would change the one on the lumina no matter what because the gas is probably caramelized in the tank. Quote
jeremy Posted December 7, 2008 Report Posted December 7, 2008 I always forget that you have that GP too.... Quote
5speedz34 Posted December 7, 2008 Report Posted December 7, 2008 I always forget that you have that GP too.... Ya it sucks too, lol. Quote
AWeb80 Posted December 7, 2008 Report Posted December 7, 2008 change it. a little PB blaster on the metal lines 15 minutes before hand and a vice grip was all it took to get my stock one off. took me 5 minutes....even on a lowered car w/ no jacks. Quote
