Addicted to eaton Posted December 3, 2008 Report Posted December 3, 2008 Ok so my car’s power steering sucks! The rack went out causing it to leak a bottle of power steering fluid a day. I lived with that for about two weeks. Then I was in a rush and said “Fuck it†it started making a whining noise, a week later a squeak at idle. a day later the pulley that goes from the serpentine belt from the p/s pump fell off. (Making it un drivable due to no water pump or alternator) So now when my power steering rack gets here I'm going to put a new power steering pump, and the used rack in it. Just not sure all I need what I need: 1. new p/s pump $87.99 rock auto 2. p/s rack What else do I need? Quote
95 vert Posted December 3, 2008 Report Posted December 3, 2008 High pressure hose. Those usually leak. And fluid of course! Quote
pontiacmaniac94 Posted December 3, 2008 Report Posted December 3, 2008 High pressure hose. Those usually leak. And fluid of course! x2 and also about 15 hours of your life. and patience. a lot of that. i did the rac on mine over fall break, it sucked. Quote
Addicted to eaton Posted December 4, 2008 Author Report Posted December 4, 2008 High pressure hose. Those usually leak. And fluid of course! Humm ok! any gaskets or anything else? Quote
TurboSedan Posted December 5, 2008 Report Posted December 5, 2008 you might buy one of those cheap inline screen filters that go into the return line. Quote
White93z34 Posted December 5, 2008 Report Posted December 5, 2008 a pulley remover and installer tool Quote
