3100 A/C Delete/Bypass Write-Up
Well, ive had a shot compressor for a while on my 96 CS. This summer I removed ALL the lines, leaving only the evap core (didnt feel like removing the dash again :lol:), compressor, and condensor. I picked up the A/C bypass pulley kit from Napa. Ran me $36 Installation was a breeze. Best if the car was on a lift.
Part number through Napa is 600-1853. List price is $51.95, My shop discount made it $36.87 :mrgreen:
-Evacuate A/C system if not already done
-Remove serpentine belt, auto tensioner only needs a 3/8" drive ratchet
-Unbolt lines to compressor. Should be a 10mm bolt holding them on
-Cut, remove,ziptie the lines outta the way, do what you want with them. I just removed all of them
-Unplug electrical connection to the compressor, flat blade screwdriver works best
-Ziptie electical connector outta the way or cut it off and seal the ends
-Unbolt compressor from engine. 3 15mm bolts. I used air tools, but a 15mm deepwell and a ratchet works
-Drop compressor out, discard, pee on it, shoot it, do what you want with it :lol:
-Install bypass bracket and pulley unit with 3 15mm bolts
-Tighten securely
-Install serpentine belt, making sure its on the grooves correctly
-Start engine and run for 5 minutes, watching to make sure belt tracks right. Dont stand in its path if it flies off
-Turn off engine
-Retorque bypass unit bolts, making sure they are plenty snug
Now enjoy not having a noisy or seized compressor robbing you of power and gas mileage!!! I know mine was horrible! :willynilly:
Mine has been seized for about a year, its was pretty hard to turn it by hand on just the pulley. Trying to turn it with the clutch was almost impossible
nice. I did mine 2 years ago and i was afraid it was going to be shitty for design but it still works great. Also very easy to install
