ssspeedstreet Posted November 28, 2008 Report Posted November 28, 2008 While I had my LQ1 apart I had the UIM powder coated. That required pulling everything off the manifold, including the screw that acts as a closed throttle stop. How do I know if I have that adjusted correctly? Thanks for any help you can give me. ~Neil Quote
BXX Posted November 28, 2008 Report Posted November 28, 2008 You will need a DOM and mearure voltage and make sure it is witing spec with the TB closed and resting on the stop. Adjust stop until the voltage is correct. Quote
ssspeedstreet Posted November 29, 2008 Author Report Posted November 29, 2008 You will need a DOM and measure voltage and make sure it is within spec with the TB closed and resting on the stop. Adjust stop until the voltage is correct. By voltage, you mean from the TPS? Quote
BXX Posted November 29, 2008 Report Posted November 29, 2008 You will need a DOM and measure voltage and make sure it is within spec with the TB closed and resting on the stop. Adjust stop until the voltage is correct. By voltage, you mean from the TPS? Yes Quote
ssspeedstreet Posted November 29, 2008 Author Report Posted November 29, 2008 Couldn't be easier than that. Thanks for your help. Quote
