CSI_MuNkY Posted October 17, 2008 Report Posted October 17, 2008 Whats the deadline for this? Slick, what did you research that made you switch to 3"? I'm intrigued... Jamie EDIT: Guys, I split this discussion from the exhaust system group buy. - Robby1870 Quote
slick Posted October 17, 2008 Report Posted October 17, 2008 Whats the deadline for this? Slick, what did you research that made you switch to 3"? I'm intrigued... Jamie I guess for a forced induction vehicle, you actually want as much airflow as possible, and as little resistance as possible in the exhaust. I've been recommended, by several people, to go with a 3". Quote
CSI_MuNkY Posted October 17, 2008 Author Report Posted October 17, 2008 Whats the deadline for this? Slick, what did you research that made you switch to 3"? I'm intrigued... Jamie I guess for a forced induction vehicle, you actually want as much airflow as possible, and as little resistance as possible in the exhaust. I've been recommended, by several people, to go with a 3". I might just have to go 3" too if I can get in on this... I do plan to "force" a little more air into the car at some point in the coming years.... Jamie Quote
Addicted To Boost Posted October 18, 2008 Report Posted October 18, 2008 Whats the deadline for this? Slick, what did you research that made you switch to 3"? I'm intrigued... Jamie I guess for a forced induction vehicle, you actually want as much airflow as possible, and as little resistance as possible in the exhaust. I've been recommended, by several people, to go with a 3". Chris, it won't do you any good to step up to a 3" exhaust system if you don't upgrade your factory 2.25" downpipe. Going from a 2.25" DP to a 3" exhaust may actually hurt your exhaust flow due to a drop in velocity. Quote
slick Posted October 18, 2008 Report Posted October 18, 2008 Whats the deadline for this? Slick, what did you research that made you switch to 3"? I'm intrigued... Jamie I guess for a forced induction vehicle, you actually want as much airflow as possible, and as little resistance as possible in the exhaust. I've been recommended, by several people, to go with a 3". Chris, it won't do you any good to step up to a 3" exhaust system if you don't upgrade your factory 2.25" downpipe. Going from a 2.25" DP to a 3" exhaust may actually hurt your exhaust flow due to a drop in velocity. Yep, I know. A 3" downpipe is already in the works. It was actually my plan to run a 3" downpipe from the beginning. Quote
Addicted To Boost Posted October 18, 2008 Report Posted October 18, 2008 How are you planning to run a 3" DP? The biggest DP you can run with an auto tranny and without cutting up the firewall is 2.5". There is a thread about it on TGPforums. Quote
slick Posted October 18, 2008 Report Posted October 18, 2008 How are you planning to run a 3" DP? The biggest DP you can run with an auto tranny and without cutting up the firewall is 2.5". There is a thread about it on TGPforums. I've fit a 3" downpipe behind the 3.4 with an auto trans. Quote
Addicted To Boost Posted October 18, 2008 Report Posted October 18, 2008 http://www.tgpforums.com/index.php/topic,3944.msg26616.html#msg26616 Flybynite has already tried it. The biggest DP you can get away with on a 3.1 Turbo with the auto is 2.5". Quote
slick Posted October 18, 2008 Report Posted October 18, 2008 http://www.tgpforums.com/index.php/topic,3944.msg26616.html#msg26616 Flybynite has already tried it. The biggest DP you can get away with on a 3.1 Turbo with the auto is 2.5". Wow, that really sucks. Guess I'm stuck with the 2.5" exhaust. Quote
Garrett Powered Posted October 19, 2008 Report Posted October 19, 2008 turbo gtu had a 3 inch downpipe. Quote
Addicted To Boost Posted October 19, 2008 Report Posted October 19, 2008 turbo gtu had a 3 inch downpipe. Isn't that in a J-body though? Flybynite proved that it won't work on a 3.1 Turbo/Auto w-body. Quote
Garrett Powered Posted October 19, 2008 Report Posted October 19, 2008 he had it on a tgp. http://www.tercelreference.com/tercel_info/turbo_exhaust_theory/turbo_exhaust_theory.html here, read this article. obviously you guys missed it a few pages back it was posted. there is no way going from 2.5 DP to 3 " exhaust is going to hurt your exhaust flow. Quote
Addicted To Boost Posted October 19, 2008 Report Posted October 19, 2008 he had it on a tgp. http://www.tercelreference.com/tercel_info/turbo_exhaust_theory/turbo_exhaust_theory.html here, read this article. obviously you guys missed it a few pages back it was posted. there is no way going from 2.5 DP to 3 " exhaust is going to hurt your exhaust flow. He must have cut up his firewall to fit it on there.. True, it won't hurt flow, but it is kinda a waste, when you could just go straight 2.5" all the way back. The exhaust won't have very good velocity if you go from 2.5 to 3" at the DP. Quote
Garrett Powered Posted October 19, 2008 Report Posted October 19, 2008 did you read the article????? go back and read the article again. this time read it very carefully. Quote
CSI_MuNkY Posted October 19, 2008 Author Report Posted October 19, 2008 Doesn't Kuntzie have a 3" DP on his TGP as well? Jamie Quote
kuntzie Posted October 19, 2008 Report Posted October 19, 2008 Doesn't Kuntzie have a 3" DP on his TGP as well? Jamie yes full 3" with room to spare, theres one guy automatic that did a 3" aswell Quote
slick Posted October 19, 2008 Report Posted October 19, 2008 Doesn't Kuntzie have a 3" DP on his TGP as well? Jamie yes full 3" with room to spare, theres one guy automatic that did a 3" aswell Any pics or links, to both vehicles? Quote
Dark Ride Posted October 19, 2008 Report Posted October 19, 2008 Doesn't Kuntzie have a 3" DP on his TGP as well? Jamie yes full 3" with room to spare, theres one guy automatic that did a 3" aswell Any pics or links, to both vehicles? Yeah, Kuntzie I'd really like to see some pics of your exhaust/downpipe setup. Quote
GOT2B GM Posted October 19, 2008 Report Posted October 19, 2008 its the farthest thing from stock Quote
Addicted To Boost Posted October 20, 2008 Report Posted October 20, 2008 did you read the article????? go back and read the article again. this time read it very carefully. No I didn't read it. I was trying to point out that I haven't seen a TGP with a 3" downpipe without modifying the firewall. Quote
Garrett Powered Posted October 20, 2008 Report Posted October 20, 2008 Oh, I thought you were trying to argue that it would be pointless to upgrade to 3" when it is necessary for anything above 250 horse. which is not all that hard to achieve with a tgp. Quote
19Cutlass94 Posted October 21, 2008 Report Posted October 21, 2008 Theres more than enough room for a 3" dp on these cars. Mines 2.5" and theres ALOT of room. and this is a pretty good deal considering what i paid/did for my exhaust Quote
slick Posted October 21, 2008 Report Posted October 21, 2008 Theres more than enough room for a 3" dp on these cars. Mines 2.5" and theres ALOT of room. and this is a pretty good deal considering what i paid/did for my exhaust Can you get some pictures?? Quote
19Cutlass94 Posted October 21, 2008 Report Posted October 21, 2008 Theres more than enough room for a 3" dp on these cars. Mines 2.5" and theres ALOT of room. and this is a pretty good deal considering what i paid/did for my exhaust Can you get some pictures?? Of the dp on the car or just the dp? Quote
slick Posted October 21, 2008 Report Posted October 21, 2008 Theres more than enough room for a 3" dp on these cars. Mines 2.5" and theres ALOT of room. and this is a pretty good deal considering what i paid/did for my exhaust Can you get some pictures?? Of the dp on the car or just the dp? DP on the car. Quote
