GPdriver1986 Posted August 18, 2003 Report Posted August 18, 2003 Ok I'm confused about how much refrigerent I should put in my car. I read the label in the engine compartment it says I need 1lb of R-12 but I will be filling my car with r-134a (conversion kit). The kit came with 3 big cans (all in one deals).So 1lb= 16oz(right?) and 1 can has 12oz of refrigerent. I also read in the instructions that you only have to fill the r-12 system with 75-85% r-134a of the original r-12 capacity(1lb).So (12/16)x100 = 75%. AM I RIGHT? Quote
91GranSport Posted August 18, 2003 Report Posted August 18, 2003 That sounds right, but it's probably better to have a little bit less than full than have it overfull. If you're not completely sure just fill it up slowly until your feel your A/C system is running really cold and have it professionally pressure tested when you're done. Quote
no1kicker Posted August 18, 2003 Report Posted August 18, 2003 the kit at pep boys says 45 psi is what to fill it to. Quote
GPdriver1986 Posted August 18, 2003 Author Report Posted August 18, 2003 I'm an idiot, I checked again its 2.25lbs Quote
