Timm Posted November 14, 2008 Report Share Posted November 14, 2008 I'm doing a LED interior light conversion. I can get the I/P ALMOST all the way out, BUT the shifter cable holds it on! How do I remove the shifter cable? Also, With the drivers side window controller, HOW DO I OPEN IT! It's all just a giant rectangle! :-S Thanks! Quote Link to comment Share on other sites More sharing options...
BXX Posted November 14, 2008 Report Share Posted November 14, 2008 If your having trouble removing and opening parts, I dont recommend actually swapping in LEDs... removing and opening stuff is 100 times easier than swapping the LEDs I know, I did it Quote Link to comment Share on other sites More sharing options...
Timm Posted November 15, 2008 Author Report Share Posted November 15, 2008 Well I already have the 5 stock lights out, and soldered 2 LEDs into each light "hole". But I wanted to try to see if I could get the needles to be a different colour. It's all put back in right now. PICTURES! I bought 100 3mm Blue LEDs with resistors for 13.2volts. I think the eBay username was Asia Engineer, they have a VERY bad viewing angle, and direct most of the light within maybe 30*. :-/ EDIT Also took out my ABS light... I KNOW I don't have ABS. LEAVE ME ALONE! Quote Link to comment Share on other sites More sharing options...
slick Posted November 15, 2008 Report Share Posted November 15, 2008 Yeah, there are narrow angle and wide angle LED's. You just have to know what your shopping for. Quote Link to comment Share on other sites More sharing options...
blackbeauty89 Posted November 15, 2008 Report Share Posted November 15, 2008 that light surrounding your dash is sweet! where did you get it and how did you install it? Quote Link to comment Share on other sites More sharing options...
BXX Posted November 15, 2008 Report Share Posted November 15, 2008 Yeah, there are narrow angle and wide angle LED's. You just have to know what your shopping for. I have the same problem with the narrow angle, I have found ways around it for the most part. I didnt find any wide angle ones so I got the same LEDs he did.. Quote Link to comment Share on other sites More sharing options...
Timm Posted November 15, 2008 Author Report Share Posted November 15, 2008 that light surrounding your dash is sweet! where did you get it and how did you install it? http://cgi.ebay.com/ebaymotors/Parts-Accessories___1-5M-Flexible-Car-12V-Blue-Neon-Light-Wire-Cable-M6K_W0QQitemZ280285464959QQddnZPartsQ20Q26Q20AccessoriesQQddiZ2811QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item280285464959&_trksid=p4506.c0.m245&_trkparms=72%3A543|65%3A12|39%3A1|240%3A1318 I had 3 $10.00 off shipping coupons, so I looked for something with high shipping, and low price. BUT it's very dim. can't see in the daytime. Looks sweet at night. I took a dremmel to the very edge of the trim, and just pressed the light in there. Also, ships from default, default, Hong Kong Quote Link to comment Share on other sites More sharing options...
Timm Posted November 23, 2008 Author Report Share Posted November 23, 2008 So does anyone know how to remove the shifter cable from the gauge cluster? Quote Link to comment Share on other sites More sharing options...
