5speedz34 Posted November 13, 2008 Report Posted November 13, 2008 The back bolt attaches to a bracket and is just a brace. The FSM states this. Let's see the rack, frame and pretty much everything else is in the way back there. I ended up unbolted the brace and taking it out with the brace attached. I would reattach it just don't overtorque it. Quote
Regal_GS_1989 Posted November 13, 2008 Report Posted November 13, 2008 I never put that bolt back on when i did the alt on my cutlass. I remember using about 2 feet worth of extension and a swivel socket to get that bastard out from underneith. Wasn't too difficult once i figured out how to attack it. Quote
GP1138 Posted November 13, 2008 Report Posted November 13, 2008 I dread my alternator failing. I don't look forward to having to do that job at all... Quote
spiderw31 Posted November 13, 2008 Author Report Posted November 13, 2008 I dread my alternator failing. I don't look forward to having to do that job at all... That is exactly why I'm doing mine now while it is an easy task, in spite of the fact that it has not quit yet. Quote
GP1138 Posted November 14, 2008 Report Posted November 14, 2008 I dread my alternator failing. I don't look forward to having to do that job at all... That is exactly why I'm doing mine now while it is an easy task, in spite of the fact that it has not quit yet. You're asking for trouble there. What if you get a factory dud?? Quote
spiderw31 Posted November 14, 2008 Author Report Posted November 14, 2008 You're asking for trouble there. What if you get a factory dud?? Yeah, thats always possible, but its not like the one that was on there was perfect either though. The voltage seemed to drop without all that much load on it, and the bearings were starting to whine a bit. Quote
GOT2B GM Posted November 15, 2008 Report Posted November 15, 2008 Just follow slicks how to thread on LQ1 alt replacement. It is FTW. Quote
GOT2B GM Posted November 15, 2008 Report Posted November 15, 2008 http://www.w-body.com/forum/index.php?topic=30225.0 Quote
5speedz34 Posted November 15, 2008 Report Posted November 15, 2008 You need to pull the axle. With the cradle lowered you CANNOT get the Alt. back in. Maybe the 91-93 alt. Maybe if you lower the both rear cradle mounts and the passenger side you could clear the frame. YOU NEED TO PULL THE AXLE. Quote
GOT2B GM Posted November 15, 2008 Report Posted November 15, 2008 91-93 can be done with the axle in place. Quote
slick Posted November 15, 2008 Report Posted November 15, 2008 Yep, I had no issue pulling mine out with the axle in. Quote
spiderw31 Posted November 15, 2008 Author Report Posted November 15, 2008 Just follow slicks how to thread on LQ1 alt replacement. It is FTW. Oh I'm sure it is, but when I've already got the top end out of the way for other reasons, pulling the alt in 10 minutes from the top is definitely FTW! Quote
5speedz34 Posted November 15, 2008 Report Posted November 15, 2008 Yep, I had no issue pulling mine out with the axle in. You had a 94+ alt in your car. Quote
slick Posted November 15, 2008 Report Posted November 15, 2008 Dinunzio pulls his the exact same way without pulling the axle as well. Quote
5speedz34 Posted November 15, 2008 Report Posted November 15, 2008 Congrats. I'm telling you it won't fit. You told me you spent a few hours finding out how to shoe horn it in there. I'd rather pull the axle and be done with it. After I torn the boot on my inner tie rod I pulled the axle. PS-Dinunzio has the 91-93 size alt too. Quote
slick Posted November 15, 2008 Report Posted November 15, 2008 Yep, I had no issue pulling mine out with the axle in. You had a 94+ alt in your car. You need to pull the axle. With the cradle lowered you CANNOT get the Alt. back in. Maybe the 91-93 alt. Maybe if you lower the both rear cradle mounts and the passenger side you could clean the frame. YOU NEED TO PULL THE AXLE. I really don't get what your saying here. According to your posts, your saying it's not possible with the 94+, however my car had a 95 swapped engine into it, and I had no issues. The very first time was a learning experience on how to take it in and out, with just dropping the cradle. Afterwards, it was cake walk. 91-93, no issues. I had a 95 engine, which is obviously different, in my 93, and never had to pull an axle. Quote
slick Posted November 15, 2008 Report Posted November 15, 2008 Has anyone else used the 45 minute DOHC write up, besides for myself? If so, post up, because we obviously must be lying. Quote
GOT2B GM Posted November 15, 2008 Report Posted November 15, 2008 I used it no problem. Good time to replace the CPS while the alt is out. It is otherwise inaccessable on an auto LQ1 car. Quote
White93z34 Posted November 15, 2008 Report Posted November 15, 2008 I helped make it. does that count? I will bet money that I could get Tony's alt in and out without removing the axle. Quote
5speedz34 Posted November 15, 2008 Report Posted November 15, 2008 Slick why are you being a dick? We talked on the phone about this. I'm telling you on the 94+ style alternators you need to pull the axle. Simple as that. The cradle doesn't lower enough to give you the space you need. Everyone's car in this thread has the smaller style alternator. Quote
5speedz34 Posted November 15, 2008 Report Posted November 15, 2008 Chris, didn't you have a 91-93 alt on a 94+ engine? The engine really doesn't matter its the size of the alt. It doesn't mount much differently on a 94+ car. Quote
GOT2B GM Posted November 15, 2008 Report Posted November 15, 2008 isnt the 94+ alt smaller in size? Quote
5speedz34 Posted November 15, 2008 Report Posted November 15, 2008 Larger. What I dislike is the fact that the FAQ is locked and I can't comment at all on it. EDIT: The cases are different between the 91-93 ALT's and the 94+ Alt. The 94+ is bigger. It will not clear that's what I'm saying. Chris, did you have a 94+ alt in your car or the 91-93 alt in your car? Quote
slick Posted November 15, 2008 Report Posted November 15, 2008 Yes, I had 94+ alternator's on my vehicle, and I had 91-93 alternators on my vehicle. In fact, I distinctly remember swapping plugs at one point because I switched from the one style to the other. Both came out EXACTLY the same. Also, I want to know what is so different between a 93 and a 94 car that the cradle doesn't drop enough?? Quote
slick Posted November 15, 2008 Report Posted November 15, 2008 Slick why are you being a dick? We talked on the phone about this. I'm telling you on the 94+ style alternators you need to pull the axle. Simple as that. The cradle doesn't lower enough to give you the space you need. Everyone's car in this thread has the smaller style alternator. About 3 months ago. And I told you, the first time I did it, I had to figure it out. Afterwards, I could get it in and out no problems. You have to rotate the alternator in the hole before it will come out. Once you have it rotated, it will slide out with plenty of room to play. I've told you this several times. Quote
