jdm lumina Posted November 8, 2008 Report Share Posted November 8, 2008 will 06 impala rims 17x6.5 fit on a 91 lumina euro? Quote Link to comment Share on other sites More sharing options...
pontiacmaniac94 Posted November 8, 2008 Report Share Posted November 8, 2008 will 06 impala rims 17x6.5 fit on a 91 lumina euro? i am not 100% sure, and I garauntee you there is someone on here that will tell you, but I am pretty sure unless you use spacers to clear the calipers, it will not work. Quote Link to comment Share on other sites More sharing options...
jdm lumina Posted November 8, 2008 Author Report Share Posted November 8, 2008 thanks. i was thinking the same thing. Quote Link to comment Share on other sites More sharing options...
Breakdown Posted November 8, 2008 Report Share Posted November 8, 2008 will 06 impala rims 17x6.5 fit on a 91 lumina euro? If they're anything like the other 1st gens and 2nd Gen comparisons. You'll need to space them out. Here's the hook. Once you get enough spacer plates in to clear the calipers you won't be able to safely get enough turns on the lugs because of eating up the space. You have two options, a spacer adapters (much more expensive than plates) or getting longer studs. It's not plug and play to the best of my knowledge. Quote Link to comment Share on other sites More sharing options...
