Oil Pump Drive Seal - LQ1 - Pictures
Hey everyone, I found many posts on how to replace/fix this leak but every post is missing the pictures or the pictures are broken links
Does anyone have these handy
http://www.w-body.com/forum/index.php?topic=71624.0
That thread has a very nice picture of where the seal is located. It does not have the procedure, but the procedure is fairly straightforward once you get the cam-carriers off. Keep in mind you have to re-time the motor again after doing this, and some people opt to just coat the existing seal with RTV.
If you open it up and put a new o-ring in, you may as well also install a SBC V8 distributor gasket on there too, for an extra ounce (ok, gram) of protection
