Rdrckt_92 Posted November 3, 2008 Report Share Posted November 3, 2008 ok, Do the older 88-90? DICs use the same connector that the 91-93 DICs does? Dan Quote Link to comment Share on other sites More sharing options...
5speedz34 Posted November 3, 2008 Report Share Posted November 3, 2008 I want to say no. Here is a better question....Is the "car" that is on the 91-93 cars. If its a 4door does the image show a 4 door and if its a 2 door show a 2 door car? Also, the DIC's are not specific for a STE right? You can put a STE DIC into a non STE car the only thing that makes it special is the wiring inside the car not the DIC itself right? Quote Link to comment Share on other sites More sharing options...
Rdrckt_92 Posted November 3, 2008 Author Report Share Posted November 3, 2008 the dic and the harness came from 2 different cars. The DIC is from a '92 GTP and the DIC harness is from a TGP. I'm wondering because I see one large white connector that looks like is could be it, but it is too large for the DIC thats going into the car. It could be another connector soemwhere else on the harness, and I'm just not seeing it, the harness is HUGE Quote Link to comment Share on other sites More sharing options...
5speedz34 Posted November 3, 2008 Report Share Posted November 3, 2008 Try connecting it? But I'm fairly certain they are different. Quote Link to comment Share on other sites More sharing options...
AWeb80 Posted November 3, 2008 Report Share Posted November 3, 2008 the pig tails are the same.....I'm almost 100% sure of this..... I'd check gearheads website though Quote Link to comment Share on other sites More sharing options...
grandprixnyc Posted November 4, 2008 Report Share Posted November 4, 2008 They are physically the same. The pinouts are identical as far as FSM's go as well. Quote Link to comment Share on other sites More sharing options...
grandprixnyc Posted November 4, 2008 Report Share Posted November 4, 2008 PS... Sounds like you might have the end of the harness that plugs into the C200 on the firewall, and you're missing the blue 16 pin that goes into the DIC. Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted November 4, 2008 Report Share Posted November 4, 2008 Same. I put a newer one in my TGP. I think the one in the 90 Turbo STE is the same as 91-93. Quote Link to comment Share on other sites More sharing options...
grandprixnyc Posted November 4, 2008 Report Share Posted November 4, 2008 Same. I put a newer one in my TGP. I think the one in the 90 Turbo STE is the same as 91-93. They are identical. Quote Link to comment Share on other sites More sharing options...
Night Fury Posted November 4, 2008 Report Share Posted November 4, 2008 I want to say no. Here is a better question....Is the "car" that is on the 91-93 cars. If its a 4door does the image show a 4 door and if its a 2 door show a 2 door car? Also, the DIC's are not specific for a STE right? You can put a STE DIC into a non STE car the only thing that makes it special is the wiring inside the car not the DIC itself right? I don't think anyone answered this one! Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted November 4, 2008 Report Share Posted November 4, 2008 I'm pretty sure they all show a 4-door car, because only STE's had the extra monitoring function enabled. Quote Link to comment Share on other sites More sharing options...
grandprixnyc Posted November 4, 2008 Report Share Posted November 4, 2008 My car is a 2-door and had the DIC in it from the factory, and it showed a sedan on the screen. They all came this way. Only (T)STE's had functioning icons in them, though. Wiring that in to a coupe is a PITA! Quote Link to comment Share on other sites More sharing options...
5speedz34 Posted November 5, 2008 Report Share Posted November 5, 2008 Good to know GM is that cheap. Quote Link to comment Share on other sites More sharing options...
Night Fury Posted November 5, 2008 Report Share Posted November 5, 2008 Yeah. That sucks. Quote Link to comment Share on other sites More sharing options...
grandprixnyc Posted November 7, 2008 Report Share Posted November 7, 2008 Good to know GM is that cheap. Yeah, it sucks. There's no reason the GTP shouldn't have had functioning icons. At any rate kid, this thing will work fine in your car, just get the other end of the harness. Quote Link to comment Share on other sites More sharing options...
