rough idle
i just got done putting the intake plenum back on..and when i started it, it started running rough and the rpms were going from 2.5k - 1k. Any suggestions?
Did you let the car idle for about 10mins?
Sounds like the Idle Pintle Valve is trying to re-set.
Do an idle re-learn process if problem continues.
- Erik
i found and fixed the problem...the throttle body gasket was half on and covering half the inlet. I was all heated from the hoses going to the TB that I let this little detail slip by.
