kelton57 Posted October 30, 2008 Report Posted October 30, 2008 Can a heater core leak down the firewall on the engine side of the firewall. I've checked the heater hose connections at the firewall and they are dry, but I have a steady stream of water coming down the firewall on the passenger side after the system pressurizes when running. There does not appear to be a leak inside the car nor do I smell anti-freeze like you usually do with a heater core leak. Also do you access the heater core from the engine side or from the interior?. My car is a '91 lumina two door with the usual 3.1. Quote
