HELP! Stranded! Either ignition switch or starter went out
The battery is strong but when I turn key to start position nothing happens. Can I run a jumper cable from the battery and touch the solenoid terminal to see if it starts? I remember doing this with other cars. Where is the solenoid anyway? is it underneath near the starter? I just need to get it started one more time to get it to the mechanic. Any tips or help would be appreciated!
hit the starter with a screwdriver a few times and try starting it ive seen a that work many times
OK I'll try that first, any other tips before I leave? I want to get as much help as I can before I get a ride to the car. The car is on the other side of town. thanks!
Is the security light blinking when you try to start it?
EDIT- I just saw that its an 88.. I doubt it has the vats system then..
where is the security light?? the dashboard is digital display
You don't have one... I didn't see that it was an 88 until after I posted...
Is there a trick where I can put ignition in ON position, wait 10 minutes, then turn OFF then try to start it?
I used to drive an 89 Chevy pickup that had some starter trouble.. What worked for me sometimes, was just turning the key from run to start a bunch of times real fast, and usually the starter would take off one of those times...
I got the car started. I had to play around with the ignition though. But it started like usual, I didn't hear any weird noises from the starter. I'm think the ignition switch is bad but I got it replaced brand new 2 years ago. I thought it would last longer than that. Can I buy something to spray in there to clean it out? Could it be the VATS that has gone bad? I get the same car starting problem with the spare key. I also thought maybe the ground wire from the battery terminal to the body might be bad but it looked OK
Does your key look like this?
NO unless its a corvette they didnt have that system insalled on a 1988 check the aux power post bolt.
