red95cutlass Posted October 26, 2008 Report Posted October 26, 2008 I removed and replaced the throttle body and upper intake for some work I was doing. Now that I got it back together, the RPMs are at 1500 but when I started they were at 6-700. Can anyone tell me the process to go through to reset the idle back to where it is supposed to be? Thanks. Quote
red95cutlass Posted October 26, 2008 Author Report Posted October 26, 2008 Sorry, 1995 cutlass supreme convert. 3.4 L Quote
AL Posted October 26, 2008 Report Posted October 26, 2008 This was my problem... This came unplugged in the back by the firewall... Might wanna check that. Quote
red95cutlass Posted October 26, 2008 Author Report Posted October 26, 2008 my assumption is that whenever any work like this is done that you have to readjust the throttle? Is this true? Let me know. Quote
Andrew Posted October 26, 2008 Report Posted October 26, 2008 if you disconnected the battery, then yes do an idle relearn. if not, then you have a vac leak somewhere. Quote
