MikeP2389 Posted October 25, 2008 Report Posted October 25, 2008 So soon im going to do a pan drop and filter change on the 02 ss and nobody around here sells any gm dexroniii. Is it ok to juss throw some dexron 6 in there? cuz i hear it should be compatible and is better. thanks. Quote
Crazy K Posted October 25, 2008 Report Posted October 25, 2008 WHAT? i think Detron VI can be compatible... but I think it is fully synthetic, and supposedly not that good. Check again. i use the super tech multipurpose fluid from wally-world. *made by Warren Petroleum products!* Quote
5speedz34 Posted October 25, 2008 Report Posted October 25, 2008 Dexron VI is fully compatible in older transmissions I have it in the GP no issues after 400 miles Quote
rockfangd Posted October 25, 2008 Report Posted October 25, 2008 i always use the valvoling merc3 HM and i have never had a problem. I get it from advanced auto Quote
MikeP2389 Posted October 25, 2008 Author Report Posted October 25, 2008 so its ok to mix in with the leftover Dexron III in the tranny then? i could prolly get some castrol dexronIII equivalent from advance should i juss use that? Quote
rockfangd Posted October 25, 2008 Report Posted October 25, 2008 I dont see why that would be an issue but really there isnt too much of a difference. Both are good Quote
MikeP2389 Posted October 25, 2008 Author Report Posted October 25, 2008 i think i might juss go with the castrol or valvoline then. Quote
5speedz34 Posted October 25, 2008 Report Posted October 25, 2008 Valvoline Dexron VI. Just let it drain for a good amount of time if you can. Quote
mcbfarm Posted October 25, 2008 Report Posted October 25, 2008 Don't mix 'em if you can avoid it. Either new and changed ever 15000 is better than either otherwise. Follow the filling instructions carefully -- easy to overfill (not good -- blows seals) and a pain to get out. Take the old and put it in containers, and when you add the new start with 1 quart less than came out, and add a pint at a time, checking the fluid each time. Quote
MikeP2389 Posted October 25, 2008 Author Report Posted October 25, 2008 well ive been reading around and gm recommends VI to be used in trannys that use the older versions of dexron. so it will be ok to mix em. im just prolly gonna get the gm dexron VI from the dealer and use that with the pan drop. Quote
Dark Ride Posted October 25, 2008 Report Posted October 25, 2008 I mixed dexcron III and VI without problems in the lumina Quote
jerry455 Posted October 25, 2008 Report Posted October 25, 2008 have used the dexron vi since it became available. it is improved in every way over dexron III. same as dexronIII is better than dexron II. have used it in 700r4, 4t65e and 4t60. Quote
MikeP2389 Posted October 26, 2008 Author Report Posted October 26, 2008 yea thats what ill go with then. is 7quarts enough for a pan drop? Quote
1990lumina Posted October 26, 2008 Report Posted October 26, 2008 Should be way more than enough. Remember your torque converter holds half the fluid so you'll only get about half or less out of the tranny with a pan drop. Quote
Andrew Posted October 26, 2008 Report Posted October 26, 2008 yea thats what ill go with then. is 7quarts enough for a pan drop? should be about 6. Quote
MikeP2389 Posted October 26, 2008 Author Report Posted October 26, 2008 really 9? that much for a pan drop? Quote
Andrew Posted October 26, 2008 Report Posted October 26, 2008 yeah really Ken? it was only 6 for me when i did it on the 98 GP. Quote
tdvs Posted October 27, 2008 Report Posted October 27, 2008 Just did mine the other day - '95 3.4 - 7 qts. Tom Quote
BIGBULS Posted October 30, 2008 Report Posted October 30, 2008 7qts should be more than enough. Spec is only 6qts IIRC for a 60-E, although most seem to take 6 and a half or so to actually get them to the full line warmed up.......... And yes, Dex VI is FULLY compatible with Dex III..........we use it ALL the time and no issues yet (on hundreds of cars). Quote
MikeP2389 Posted October 30, 2008 Author Report Posted October 30, 2008 nice juss picked up 7qts of dex vi from the chevy dealer this afternoon. Quote
