cant find 02 sensor plug on 97 dohc...
I cant find the plug for it in the wiring harness.. Anybody have an idea of where it might be?
best shot at this area (I'm assuming the front O2 sensor) is from under the car. Use ramps or jack stands, not any kind of jack. The connector can dangle in sight, or get caught up on something just out of sight from above, especially if that's how you removed it. Even from below you might need to feel around blind and then carefully untangle what it's hung up on. If the engine got removed and put back less than perfectly, that connector can end up hiding about anywhere in the engine compartment! Hopefully that's all you have off...
