pontiacmaniac94 Posted October 22, 2008 Report Posted October 22, 2008 will that work? will i still be able to use the airbag? i have a 94 gp, and i am thinkin about gettin a steering wheel off of a 01 gp, would they still be functional? or no? how new can i go that they would swap? thanks! Quote
White93z34 Posted October 22, 2008 Report Posted October 22, 2008 a 2001 would have dual-stage airbags, so the airbag would not work. a airbag from a 97' would work. Quote
pontiacmaniac94 Posted October 22, 2008 Author Report Posted October 22, 2008 a 2001 would have dual-stage airbags, so the airbag would not work. a airbag from a 97' would work. okay, so only 97? or whatelse, what would the newest year? Quote
White93z34 Posted October 22, 2008 Report Posted October 22, 2008 i believe 97 would be as new as you could go, as from what I understand 1998 was mandatory dual stage airbags in everything. I don't know what the montanas had, that might be a place to look. Quote
pontiacmaniac94 Posted October 22, 2008 Author Report Posted October 22, 2008 i believe 97 would be as new as you could go, as from what I understand 1998 was mandatory dual stage airbags in everything. I don't know what the montanas had, that might be a place to look. okay, i was wondering.....i am replacing the turn signal switch, so i figure i might as well swap out the steering wheel as well!! thanks for the info. Quote
GJD5 Posted October 23, 2008 Report Posted October 23, 2008 You can use the 97+ steering wheels but the airbag itself has to be for a 97. The plug is different on the 98+. I have a 2000 steering wheel on my 96 GP with a 97 airbag. Also, FYI, I did notice the 98+ steering wheels were lighter because they are aluminum. Quote
5speedz34 Posted October 23, 2008 Report Posted October 23, 2008 There is a thread on this in this section! Search for it. You need a '97 only airbag, any 97-00 wheel will work. Remember the wheels in 01 the GP's got new steering wheels. Quote
GP1138 Posted October 23, 2008 Report Posted October 23, 2008 I was going to do this in my car. I might see if I can grab a newer Olds wheel with some newer RSWC. Quote
pontiacmaniac94 Posted October 23, 2008 Author Report Posted October 23, 2008 There is a thread on this in this section! Search for it. You need a '97 only airbag, any 97-00 wheel will work. Remember the wheels in 01 the GP's got new steering wheels. search for it?!?!?!?! come on man! you know the search is not the best on here! thanks for the info! that is definitely awesome! Quote
5speedz34 Posted October 23, 2008 Report Posted October 23, 2008 I found it with no problem.....I don't have the link anymore and I don't know a ton about it. Quote
oldscsc Posted October 23, 2008 Report Posted October 23, 2008 http://www.w-body.com/forum/index.php?topic=54357.0 Quote
Timm Posted October 23, 2008 Report Posted October 23, 2008 search for it?!?!?!?! come on man! you know the search is not the best on here! x2 Quote
GP1138 Posted October 23, 2008 Report Posted October 23, 2008 search for it?!?!?!?! come on man! you know the search is not the best on here! x2 All you have to do is click "Advanced Search". Then it works. Most people need to learn how to search properly, using AND/OR operators, and quotes. Quote
5speedz34 Posted October 23, 2008 Report Posted October 23, 2008 You know the name for those operators is the borreal operators? Quote
Timm Posted October 23, 2008 Report Posted October 23, 2008 Yea, I figured out the search, but it usually turns up irrelevant things. And you're stuck with maybe 10-20 pages of material. Which you usually end up going through, just to find that they never went over your topic before. I've been there plenty of times. And by the time I'm done searching, I'm exhausted and get a little sick of the website altogether. (Don't get me wrong, I love this website, but I get frustrated!) And I'm really contemplating weather or not to post this, as I know I'll probably get screamed at by someone who doesn't relate to what I go through with this "search". But I'll post anyway. Too much typing to throw away! And best of all, probably nothing in this comment will make sense! Quote
oldscsc Posted October 23, 2008 Report Posted October 23, 2008 You know the name for those operators is the borreal operators? It's Boolean. Quote
5speedz34 Posted October 23, 2008 Report Posted October 23, 2008 You know the name for those operators is the borreal operators? It's Boolean. Thanks dude! I had that as a question on a Communications test. Quote
pontiacmaniac94 Posted October 24, 2008 Author Report Posted October 24, 2008 search for it?!?!?!?! come on man! you know the search is not the best on here! x2 OR I just post up a new topic, and people do the searching for me!! woohoo! Management FTW! Quote
oldscsc Posted October 24, 2008 Report Posted October 24, 2008 You know the name for those operators is the borreal operators? It's Boolean. Thanks dude! I had that as a question on a Communications test. Ya, never thought I'd ever use that word outside of school Quote
