AL Posted October 17, 2008 Report Posted October 17, 2008 This is for the 3.4 Automatic final drive is 3.43 correct? Anyone know what the ratios are with the 5 speed trans? Or where I can find that information. Quote
oldscsc Posted October 17, 2008 Report Posted October 17, 2008 I've been wondering this too...I was thinking 3.42's maybe. Quote
BIGBULS Posted October 17, 2008 Report Posted October 17, 2008 Getrag HM-284 gear ratios: 1st 3.46 2nd 2.28 3rd 1.48 4th 1.09 5th 0.72 Axle 3.67 This means at the 7000rpm rev limiter with 245/50R16 tires (and the more common 225/60R16 tires are 3% taller) you will be at the following speeds (I've GPS'ed these): 1st 40mph 2nd 61mph 3rd 95mph 4th 130mph 5th a LOT (about 200mph if you had the power) But most hit the top speed governor around about 124-127mph at 6600ish rpm in 4th (4300ish rpm in 5th). In *MY* opinion, 2nd could be about 5% longer (the 2-3 shift is too wide) and 5th could be about 5% shorter (it's worthless except as a cruising gear), but 1st, 3rd and 4th are fine............ Quote
oldscsc Posted October 17, 2008 Report Posted October 17, 2008 Getrag HM-284 gear ratios: 1st 3.46 2nd 2.28 3rd 1.48 4th 1.09 5th 0.72 Axle 3.67 This means at the 7000rpm rev limiter with 245/50R16 tires (and the more common 225/60R16 tires are 3% taller) you will be at the following speeds (I've GPS'ed these): 1st 40mph 2nd 61mph 3rd 95mph 4th 130mph 5th a LOT (about 200mph if you had the power) But most hit the top speed governor around about 124-127mph at 6600ish rpm in 4th (4300ish rpm in 5th). In *MY* opinion, 2nd could be about 5% longer (the 2-3 shift is too wide) and 5th could be about 5% shorter (it's worthless except as a cruising gear), but 1st, 3rd and 4th are fine............ I know the ratios are different (also considering the 4T-60E has one less gear) at WOT, my car will shift at 6400 RPM at 45 MPH FWIW. Quote
AL Posted October 18, 2008 Author Report Posted October 18, 2008 Awesome! Thanks! Do you know where the Rpm's are at 65 in 5th gear? 1700? Quote
Addicted To Boost Posted October 18, 2008 Report Posted October 18, 2008 If the gearing is anything like a 282, you will be well over 2k at 65 MPH. My old 89 GP SE with the 282 5-speed did 2,000 RPM at 55 MPH and approximately 2,800 RPM at 70 MPH. Quote
Night Fury Posted October 18, 2008 Report Posted October 18, 2008 Why is it that 5-speeds generally rev higher than autos? Quote
AL Posted October 18, 2008 Author Report Posted October 18, 2008 My automatic is 2k at 60... Why wouldnt the five speed be lower? Quote
oldscsc Posted October 18, 2008 Report Posted October 18, 2008 My automatic is 2k at 60... Why wouldnt the five speed be lower? Autos have overdrive. Some manuals do, but the 284 is just a 5-speed. 99% sure. Quote
Jonpro03 Posted October 18, 2008 Report Posted October 18, 2008 My automatic is 2k at 60... Why wouldnt the five speed be lower? Autos have overdrive. Some manuals do, but the 284 is just a 5-speed. 99% sure. I didn't think our auto's had overdrive. I thought we had 4speeds and a tcc Quote
AL Posted October 18, 2008 Author Report Posted October 18, 2008 So the 5th gear should be around the same ratio as overdrive right? Quote
Night Fury Posted October 18, 2008 Report Posted October 18, 2008 That's what I would think, but obviously not... Quote
Addicted To Boost Posted October 18, 2008 Report Posted October 18, 2008 5-speeds still have overdrive. Any number lower than 1.000 is an overdrive gear. My automatic is 2k at 60... Why wouldnt the five speed be lower? Compare the gearing of your 4T60 versus the gearing of the 284. The autos are geared taller than the 282 or 284. Quote
AL Posted October 18, 2008 Author Report Posted October 18, 2008 What is the automatics ratios... I would like to compare Quote
Addicted To Boost Posted October 18, 2008 Report Posted October 18, 2008 So the 5th gear should be around the same ratio as overdrive right? The number of gears in your transmission has nothing to do with how high it revs in top gear. It all has to do with gear ratios. For example, the 4T60HD in my TGP has the following gear ratios: 1st 2.92 2nd 1.56 3rd 1.00 4th (OD) 0.70 Final Drive: 3.33:1 Now look at this. Any gear ratio that is higher than 1.000 is an UNDERDRIVE. Any ratio that is equal to 1.000 is a DIRECT DRIVE. Any ratio that is lower than 1.000 is an OVERDRIVE. Now being that the 284 has a higher Final Drive and a higher top gear ratio, it is going to rev higher than a 4T60. Quote
oldscsc Posted October 18, 2008 Report Posted October 18, 2008 Do you have the normal 4T60-E ratios and/or FDR? Quote
Addicted To Boost Posted October 18, 2008 Report Posted October 18, 2008 I do not know what the 4T60-E ratios are. Try using the search function Quote
jake91 Posted October 18, 2008 Report Posted October 18, 2008 here is a link about gm transmissions http://www.gmtuners.com/gmtransinfo.htm Quote
oldscsc Posted October 18, 2008 Report Posted October 18, 2008 here is a link about gm transmissions http://www.gmtuners.com/gmtransinfo.htm Thanks, I wonder which ratio LQ1 convertibles got...or if there were options? Quote
jake91 Posted October 18, 2008 Report Posted October 18, 2008 if you go back to that link and click on (click hear for application details) next to 4t60-E it gives a list of cars it was in with ratios and it tells about the lq1 Quote
oldscsc Posted October 18, 2008 Report Posted October 18, 2008 if you go back to that link and click on (click hear for application details) next to 4t60-E it gives a list of cars it was in with ratios and it tells about the lq1 3.43 FDR with a 2060 stall. Thanks again. Quote
AL Posted October 18, 2008 Author Report Posted October 18, 2008 Nice find Jake! # 1st -- 2.921 # 2nd -- 1.568 # 3rd -- 1.000 # 4th -- 0.705 # Rev -- 2.385 Quote
