ZacksZ34 Posted October 16, 2008 Report Posted October 16, 2008 okay i just found out my trannys goin in the Z and was wondering if a ranny from a monte z34 would work in my lumina Quote
GP1138 Posted October 16, 2008 Report Posted October 16, 2008 okay i just found out my trannys goin in the Z and was wondering if a ranny from a monte z34 would work in my lumina Yes, it should work fine as long as it's a 4T60E. Quote
carkhz316 Posted October 16, 2008 Report Posted October 16, 2008 Should. Both 4T60-E. Up to '97 Quote
oldscsc Posted October 16, 2008 Report Posted October 16, 2008 How do you know the tranny is going out? What's it doing? Quote
ZacksZ34 Posted October 16, 2008 Author Report Posted October 16, 2008 How do you know the tranny is going out? What's it doing? its not shifting into third and the tranny fluids got a burnt smell to it Quote
ManicMechanic Posted October 16, 2008 Report Posted October 16, 2008 |A| thru |C| fit as shown in notes. A ----------- Valve body cover is steel & has no engine mounting bosses . |B| & |C| fit by transferring valve body wiring harness, solenoids & electrical connector in case as needed. A ---------- CUTLASS 91-92 A.T.; 4T60E (3.4L only) GRAND PRIX 91-92 A.T.; 4T60E (3.4L only) LUMINA CAR 91-92 A.T.; 4T60E (3.4L) B ---------- CUTLASS 93 A.T.; 4T60E, 6-207 (3.4L) GRAND PRIX 93 A.T.; 4T60E, 6-207 (3.4L) LUMINA CAR 93 A.T.; 4T60E, 6-207 (3.4L) C ---------- CUTLASS 94-95 A.T.; 6-207 (3.4L) GRAND PRIX 94-95 A.T.; 6-207 (3.4L) LUMINA CAR 94-95 A.T.; 6-207 (3.4L) MONTE CARLO 95 A.T.; 6-207 (3.4L) Quote
oldscsc Posted October 17, 2008 Report Posted October 17, 2008 How do you know the tranny is going out? What's it doing? its not shifting into third and the tranny fluids got a burnt smell to it I'm no expert but I'd try a flush/filter change before I dropped the money for a new tranny. Quote
Euro Posted October 17, 2008 Report Posted October 17, 2008 Yeah do a trans fluid and filter change first. Spending $50 first is better than $2800 first. DONT do one of those AAMCO extreme flushes. That might cause damage instead of help. Quote
Regal_GS_1989 Posted October 17, 2008 Report Posted October 17, 2008 Yeah do a trans fluid and filter change first. Spending $50 first is better than $2800 first. DONT do one of those AAMCO extreme flushes. That might cause damage instead of help. First off. How "burnt" is the fluid. If it is still somewhat red, then fluid and filter change should do you good. If it is a little on the darker side, could be that a flush is in order. A flush can make it worse, or it can make it much much better. All depends on the type of flush. You could see if the shop could just flush it by disconnecting one of the cooler lines, then keep pouring in new fluid with the engine running until the dirty stuff is gone and the clean is coming out. Then change out the filter, top off the fluid and that could very well take care of your issue. Doing a flush this way does not subject the transmission to fluid at a higher pressure then it can pump, which could possibly loosen up some gunk inside the valve body. If the fluid is fairly dark, then also make sure to check it for metal shavings. The trans fluid in my cutlass was as black as tar and full of metal shavings from the diff packing in. I slapped in a new diff, flushed out all the old fluid like described above and then changed the filter and filled it with fresh stuff. The car drove and shifted perfect for the 2 years and 25000 km that I drove it. There is a possiblity that it could be fixed cheap and easy. Quote
ZacksZ34 Posted October 17, 2008 Author Report Posted October 17, 2008 well the garage ran a test today and theres definatly internal damage to the tranny! so the cars being parted with im not sinkin anymore money into it!!!!! Quote
ManicMechanic Posted October 17, 2008 Report Posted October 17, 2008 Same thing happened to my 1991 Lumina...3rd and 4th went. Of course the previous owner drove it in 2nd gear at 70 MPH... Quote
White93z34 Posted October 17, 2008 Report Posted October 17, 2008 well the garage ran a test today and theres definatly internal damage to the tranny! so the cars being parted with im not sinkin anymore money into it!!!!! I've told you before. I'd buy your car. and honestly a dieing trans will not phase me. Quote
ZacksZ34 Posted October 17, 2008 Author Report Posted October 17, 2008 well the garage ran a test today and theres definatly internal damage to the tranny! so the cars being parted with im not sinkin anymore money into it!!!!! I've told you before. I'd buy your car. and honestly a dieing trans will not phase me. if you want it come and get it but you will have to get it from the garage cause we signed the title over to cover the repairs bill from the topend work they did the other day Quote
IRONDOG442 Posted October 19, 2008 Report Posted October 19, 2008 well the garage ran a test today and theres definatly internal damage to the tranny! so the cars being parted with im not sinkin anymore money into it!!!!! I personally hope GULCH !! Quote
5speedz34 Posted October 20, 2008 Report Posted October 20, 2008 What top end work did they do? Quote
ManicMechanic Posted October 20, 2008 Report Posted October 20, 2008 What top end work did they do? I'm thinking the LIM gaskets. Quote
tdvs Posted October 20, 2008 Report Posted October 20, 2008 While on the trans subject, i.e. fluid and filter change, and to save an additional thread, is there a torque spec on the trans bolts? Thanks, Tom Quote
GP1138 Posted October 20, 2008 Report Posted October 20, 2008 Why even ask questions if you're not willing to do the work? Every single thread you've made has been pretty much pointless. Quote
IRONDOG442 Posted October 20, 2008 Report Posted October 20, 2008 Maybe to gage how far the repair shop is going inside his anal canal. Quote
tdvs Posted October 20, 2008 Report Posted October 20, 2008 Why even ask questions if you're not willing to do the work? Every single thread you've made has been pretty much pointless. Who is that^ directed at? I'm changing my trans fluid and filter tomorrow. That's why I asked about the torque specs on the pan bolts. Not saying what brand of filter tho Tom Quote
ManicMechanic Posted October 20, 2008 Report Posted October 20, 2008 Why even ask questions if you're not willing to do the work? Every single thread you've made has been pretty much pointless. Who is that^ directed at? I'm changing my trans fluid and filter tomorrow. That's why I asked about the torque specs on the pan bolts. Not saying what brand of filter tho Tom I'm pretty sure it was to BadTemperedZ34. All my manuals are packed away right now. I usually just snug them down evenly with a 1/4 ratchet. Quote
Euro Posted October 20, 2008 Report Posted October 20, 2008 Maybe to gage how far the repair shop is going inside his anal canal. Quote
tdvs Posted October 20, 2008 Report Posted October 20, 2008 Why even ask questions if you're not willing to do the work? Every single thread you've made has been pretty much pointless. Who is that^ directed at? I'm changing my trans fluid and filter tomorrow. That's why I asked about the torque specs on the pan bolts. Not saying what brand of filter tho Tom I'm pretty sure it was to BadTemperedZ34. All my manuals are packed away right now. I usually just snug them down evenly with a 1/4 ratchet. That's what I did on the last one, and didn't have a leak. Just thought if there was a torque spec, I'd do it that way with this one. Thanks, Tom Quote
