5speedz34 Posted October 16, 2008 Report Share Posted October 16, 2008 I want to install a non-power mast in my car. There is no mast ATM. I think I might go to the junkyard this weekend and get a non-power mast. How do I remove the non power mast? Is it just a nut underneath it? Can it be accessed by a crescent (adjustable wrench)? Quote Link to comment Share on other sites More sharing options...
slick Posted October 16, 2008 Report Share Posted October 16, 2008 http://www.mytoolstore.com/astro/7888.jpg That big long piece in there is an antenna tool. It takes off the part that is actually holding the entire antenna, on the outside, in place. Quote Link to comment Share on other sites More sharing options...
5speedz34 Posted October 16, 2008 Author Report Share Posted October 16, 2008 I'm talking specifically the mast. Which IIRC, is removed from inside the trunk? Doesn't it just have a nut holding it on? The antenna itself comes off with a 10mm wrench. Edit: It was years ago, that's why I'm asking but I know I never removed a antenna with a special tool. Quote Link to comment Share on other sites More sharing options...
Brian P Posted October 16, 2008 Report Share Posted October 16, 2008 IIRC there's a bolt that fastens a small bracket to the body. This holds the mast base in its location. I don't remember using a special tool for that piece. Quote Link to comment Share on other sites More sharing options...
rockfangd Posted October 16, 2008 Report Share Posted October 16, 2008 treis a pecial nut on the outside just underthe mast. Usually has 4 nubs and that has to b unscrewed and the unit pulls in through the trunk. Easy. I f you dont have the tool, snap ring pliers or needlenose plies would work in a pinch. I have changed so many its not even funny lol Quote Link to comment Share on other sites More sharing options...
