92 lumina high idle and cuts off
i recently got the head gaskets done. i replaced all gaskets intake, excaust, value cover, and head(the whole kit) after about 2000 miles recently the car idles at about 1500 instead 900 rpm. today i started the car and put it in reverse and it cuts off. i dont know since the power steering line is gone(which im about to fix) so anyways i restarted the car and it cuts off again. so im trying to figure out what could be the problem before i start wrenching and unscrewing.
That high idle is a common problem with many different causes on the 3.1MPFI. Try idle relearn procedure in the FAQ section
