chadz34 Posted October 11, 2008 Report Posted October 11, 2008 So, when I accelerate, I can hear a knock once the engine moves as well as letting off the gas, I can hear a knock. AFAIK the LQ1 has 3 motor mounts, I know I need the one under the hood replaced, but how will I know which lower mount is making the racket? Can anyone help out here? Thanks Quote
5speedz34 Posted October 11, 2008 Report Posted October 11, 2008 There are 3 engine mounts and 1 transmission mount. With the miles on your car I would just replace them all. It's too bad you got your transmission replaced since it would've been a perfect time to do them then. Quote
88red4cyl Posted October 11, 2008 Report Posted October 11, 2008 It's probably the lower motor mount, but like he said, now would be a good time to replace all of them... They're getting older anyway, and it'll save you some headaches on down the road... Quote
5speedz34 Posted October 11, 2008 Report Posted October 11, 2008 Realistically 100-150k is when I would replace stock mounts. Quote
White93z34 Posted October 12, 2008 Report Posted October 12, 2008 more then likely the front lower engine mount is failed, I believe it is the only fluid filled one on the car so that makes it a prime candidate for failure. personally I would go with a solid rubber one in place of it, thats what I did and I haven't looked back. Quote
Crazy K Posted October 12, 2008 Report Posted October 12, 2008 I think it is funny... that I have never experience a bad mount. well... if you exclude Pschomatt's TGP... Quote
5speedz34 Posted October 12, 2008 Report Posted October 12, 2008 I've had plenty of bad "mounts." I would get a fluid filled one unless you plan on seeing the car hit 500k. It won't go bad while you own the car. I agree with that that's probably the one bad. Quote
