daytonboi Posted October 11, 2008 Report Share Posted October 11, 2008 Well got a 96 lumina and was wondering if i could change the key cylinders to use a single double sided key...every car i've had has had this feature and i really don't want to have to fool with two separate keys. Link to comment Share on other sites More sharing options...
Euro Posted October 11, 2008 Report Share Posted October 11, 2008 There's a thread like, 2 down from yours on this topic. And I'm pretty sure that's a no Link to comment Share on other sites More sharing options...
jake91 Posted October 15, 2008 Report Share Posted October 15, 2008 couldnt you just have the doors and trunk rekeyed to match your ignition key Link to comment Share on other sites More sharing options...
Crazy K Posted October 15, 2008 Report Share Posted October 15, 2008 uh.... PROBLEM! I looked at this in a 94ish skylark... it had the double sided key, but it used a regular door/trunk key for everything else. Still 2 Keys. Link to comment Share on other sites More sharing options...
jake91 Posted October 15, 2008 Report Share Posted October 15, 2008 okay im an idiot i was comparing this to my car it has 2 single sided keys Link to comment Share on other sites More sharing options...
Pontiac6KSTEAWD Posted October 15, 2008 Report Share Posted October 15, 2008 Do you really want a single key car? If so, you just have to find a year/car that has the same groove set door lock, as your ignition cylinder key. Then get the door lock rekeyed to your ignition lock, and install. Hopefully it will be from a W body, so you can also get the weird style trunk lock. The 9C1 Caprices had this, the door/trunk key also started the car. Link to comment Share on other sites More sharing options...
Crazy K Posted October 15, 2008 Report Share Posted October 15, 2008 Hopefully it will be from a W body, so you can also get the weird style trunk lock. You must mean the physical design of the Pontiac trunk key cylinder? that has a square block instead of a flat metal bar on the back? the other W models have normal GM trunk locks. Link to comment Share on other sites More sharing options...
5speedz34 Posted October 15, 2008 Report Share Posted October 15, 2008 Just buy a second gen..... sheesh Link to comment Share on other sites More sharing options...
Crazy K Posted October 15, 2008 Report Share Posted October 15, 2008 Just buy a second gen..... sheesh You're one to talk. Link to comment Share on other sites More sharing options...
Brian P Posted October 15, 2008 Report Share Posted October 15, 2008 ^ BAM! Link to comment Share on other sites More sharing options...
Regal_GS_1989 Posted October 15, 2008 Report Share Posted October 15, 2008 Just buy a second gen..... sheesh Well then, don't buy a Regal. Mine has a double sided key....BUT IT STILL HAS 2 OF THEM!! Link to comment Share on other sites More sharing options...
5speedz34 Posted October 16, 2008 Report Share Posted October 16, 2008 Just buy a second gen..... sheesh You're one to talk. This totally flew over my head. Wut? Link to comment Share on other sites More sharing options...
IRONDOG442 Posted October 21, 2008 Report Share Posted October 21, 2008 http://www.w-body.com/forum/index.php?topic=71907.0 Link to comment Share on other sites More sharing options...
slick Posted October 23, 2008 Report Share Posted October 23, 2008 http://www.w-body.com/forum/index.php?topic=71907.0 All we need is one thread about it. Link to comment Share on other sites More sharing options...
