Will the FSTB on any 3.4 clear the reservoir on a Z-34 5-speed? If more than 1 option, which is best?
Thanks for the response. I was wondering if there was a factory bar that didn't need to be removed to service reservoir. What's the difference between a "standard" bar & a "vert" bar?
there is no standard bar. the only factory FSTB is on the cutlass verts. the bar i had that wouldnt fit was a aftermarket bar by Held. a vert bar will fit just barely on 5-speeds.
that's fit perfectly with a 3.4L vert STB, I have a STB on my GTP manual swaped and it's ok ! :)
picture :
You shouldn't have to get in to the reseviour very often if everything is functioning as it should in your clutch hydralics.
