per0781 Posted August 14, 2003 Report Posted August 14, 2003 My car started getting warmer while I was driving today. The gause was reading right under 3/4 when usually its right around 1/2. When I got home I popped the hood and noticed my overflow tank is FULL. I replaced the thermostat and water pump 2 years ago. Something must be preventing the anti freeze from flowing. Any suggestions? Thanx Quote
Slade901 Posted August 14, 2003 Report Posted August 14, 2003 It could be your radiator and engine block coolant passages have developed lots of gunks and blocking the coolant flow. The radiator is usually suseptible to gunks build up. The radiator horizontal tubes are no thicker than 1/8 inches and 1/2 inches wide. Use a radiator flush. Part of the instruction to use the radiator flush is after draining the all the coolant and then fill it with water and run the engine for 10 minutes and drain the water. Pour the radiator flush and with some water and drive the car for 3-4 hours. Drain the radiator flush and water and then fill it with water again and run the engine for 10 minutes and drain the water. Finally, pour a mixture of 70/30 coolant/water. What I can think of why the coolant reservoir is full because now the coolant could have a low boiling point and so it boils quickly and if the passages are a little blocked/restricted then they stay longer in the radiator/engine block and could not get dissipate the heat quickly. Quote
PaPaPooh Posted August 14, 2003 Report Posted August 14, 2003 you checked the fan? mine did that and it was the fan motor Quote
Whiskey River Posted August 14, 2003 Report Posted August 14, 2003 My car started getting warmer while I was driving today. The gause was reading right under 3/4 when usually its right around 1/2. When I got home I popped the hood and noticed my overflow tank is FULL. I replaced the thermostat and water pump 2 years ago. Something must be preventing the anti freeze from flowing. Any suggestions? Thanx I'm willing to bet that it's the radiator cap. If the cap is bad then it won't let the system hold pressure and your overflow tank will fill up. Quote
Robby1870 Posted August 14, 2003 Report Posted August 14, 2003 Try the cheap things first, radiator cap and T-stat. I bet its one of those. Robby Quote
92turboLE Posted August 14, 2003 Report Posted August 14, 2003 My car started getting warmer while I was driving today. The gause was reading right under 3/4 when usually its right around 1/2. When I got home I popped the hood and noticed my overflow tank is FULL. I replaced the thermostat and water pump 2 years ago. Something must be preventing the anti freeze from flowing. Any suggestions? Thanx I'm willing to bet that it's the radiator cap. If the cap is bad then it won't let the system hold pressure and your overflow tank will fill up. had that problem on my car and my motorcycles, i was gonna say that but you beat me to it.... check your cap, they are cheap and usually the problem - Justin Quote
per0781 Posted August 14, 2003 Author Report Posted August 14, 2003 well 20 minutes after this, the colant tank went back down to the normal level. I then turned the car on and ran it and the temperature gauge was normal, and the primary fan turned on when the gauge was 2 bars over half. Anyways, it still got towed to the shop and plus my charge light is back on again, and I replaced my alternator yesterday I'm ready to junk my car Quote
per0781 Posted August 14, 2003 Author Report Posted August 14, 2003 I also replaced the t-stat and water pump 2 years ago. Quote
