kevinz Posted October 10, 2008 Report Posted October 10, 2008 My 1993 Z34 has the Bose system in it...it works and sounds good (to me), except for the front driver's side speaker. It doesn;t put out hardly any sound at first, then gradually gets louder but scratchy. Could this be the high-quality :lol: :lol:Bose amp in the trunk, or could it be the speaker itself? I occasionally find Caprices with the Bose setup at the junkyard, and if it is the amp, is it the same amp as the Caprice one? If so I can grab it and try it, and if it is epic fail I can get that one rebuilt and keep truckin' with my current one while its at the shop. Or, if the speaker could be shot, is it the same as a Caprice front door speaker? Thanks for any help with this marvel of GM and BOSE engineering! :willynilly: P.S.-and yes, I am being a little sarcastic above and yes, I do like the way it sounds, which is why I want to keep it. So please don't tell me to pull it out and replace it w/ aftermarket, it isn't what I want to do. Thanks! Quote
White93z34 Posted October 11, 2008 Report Posted October 11, 2008 I'd wager that the driver it self is dead, if the amp was going more then one speaker would be involved. I used to pratically trip over bose equipped z34 luminas. as for the caprices, no idea there, if the driver is the same size and ohms out about the same. I would use it. Quote
Addicted2bass Posted October 11, 2008 Report Posted October 11, 2008 If it is the speaker you will need to find another bose speaker of the same size and OHM. Preferably another one from a Z34. If you try to put a after market speaker in there or a normal factory speaker it will not be the right OHM load. If its the amp expect to pay a premium to get it repaired. Personally i would rather just rip it all out and go with aftermarket stuff rather then try to fix and repair the BLOSE system. Quote
