EGR tube to exhaust manifold
How am I supposed to put it on a non junkyard car?
The tube is bent in such a strange shape. I'm not entirely sure how I got two off in the JY
is it damaged? It should just thread onto the fitting. IIRC your style EGR pipe has a separate fitting between the exhaust and the tube nut.
Ya know what. I think its just rusted shut. I'm gonna soak it in some WD-40 to see if that will help. Right now, when you tighten it, the whole assembly (including the piece that bolts to the plenum) spins. Thanks once again Brian P
