Easy question for 98 Lumina
Hey quick question, What would be the easiest way to take the back carpet (where the 6X9 speakers are) off and to see if i have the keyless reciever in the car? I have been meaning to look under that cloth carpet covering the back speakers but didnt know how to go about it without ripping something up.
Thanks in advance.
The victim: 1998 Chevy lumina, 3.1l
it would be easier to open the trunk and look from that way instead of taking all that off.
I did look under there in the trunk, But it being dark and with a flashlight i still didnt think i could see it or even confirm that i might have one up there. I mean it should be sitting between the 6X9's right? So i thought i could pull the carpet and at least see if there was one. I can't fit my hand in between the brace where the rear speakers sit to feel if there is something there.
well the best way is to look for a single black wire near the antenna in the rear i believe if the design did not change. Very few luminas got the feature though. You can also check your RPO codes. To pull the rear carpet i usually pull the back or the back seat and pull the 2 rear window trims and it comes right off :mrgreen:
definately check the rpo codes. im not sure what the code is. when you open the trunk up look on the lid and you will see a list of all the options the car came with.
i also have a 98 lumina. you should post up some pics of your lumi.
or just call a dealer, give them your VIN, and have them tell you if your car came equipped with it or not.
