oil pump drive shaft gasket replacement
I bought a GM oil pump drive shaft gasket and now I'm ready to replace the o-ring. I have a few questions?
1)What should be done if the whole shaft does not come out?
2)If the whole shaft comes out can it split into 2 pieces?
3)Should I remove the fuel lines?
I already went to that site,so far I have seen
w-body.com,berettastuff,v624,and 60degreev6.
1. You have to get it out, and it shouldn't be that difficult. Try a pry bar if it's stubborn. If the metal rod in the end of the shaft stays in the block, you can retrieve it with a magnet.
2. Yes, the metal rod can come out the end of the oil pump drive. It just slips in and out, so no biggie if it comes out.
3. I don't remember removing the fuel lines, but if you think it would give you more room, it wouldn't hurt to do it.
Should I bother taking out the other half if it stays inside or can I just leave it?
If it doesn't lean over and you can push the oil pump drive in completely, then I wouldn't bother removing it. I don't remember if it has enough play in it to lean over or not (been too many years). Either way, it's easy, I'm sure you won't have a problem.
