rossg Posted September 29, 2008 Report Posted September 29, 2008 here is how its done with pics. tools needed torque wrench capable of 24ft lbs fuel line disconnect tool avilable at most autoparts stores. 10 mm socket for 3/8 and 1/4 drive ratchet 3/8 swivel 1/4 ratchet 3/8 ratchet 6 inch extension for 3/8 and 1/4 inch ratchets flat head screwdriver pliers rags First disconnect the negative battery terminal. Then remove the air cleaner box and the decorative engine cover. Remove the strut support bar. take out the rear spark plug wires. Drain the Radiator in to an appropriate container!!!!!!! remove all electrical connectors, throttle cables, fuel lines and unbolt the egr. remove the 7 bolts on the intake plennum and the hose below the intake the upper plenum should then come off. next remove all the electrical connections and vacum lines you can see the wireing harness will be able to be removed if done properly. it should look like this when done. Then remove the 12 bolts that hold on the lower intake Now lift the lower intake off and clean all the maiting surfaces . It is also a good time to clean out your intake take a few cans of carb cleaner or brake and parts cleaner and a small wire brush and clean it all up it will help air flow. If you want to get crazy now would be a good time to port and polish your intake. here is what it should look like. Now simply reverse the procedure to reinstall. you should retorque the intake bolts to 24 foot lbs. Then follow the standard bleeding procedure for refilling your radiator. If done right this is an aprox 3-5 hour job I did mine in less than 3 hours. Quote
Q-Ball Posted September 30, 2008 Report Posted September 30, 2008 Awesome, this should be a sticky. Quote
slick Posted September 30, 2008 Report Posted September 30, 2008 There is no reason for the fuel line disconnect tool. Pop out the injectors and swing the rail out of your way. Quote
Addicted To Boost Posted September 30, 2008 Report Posted September 30, 2008 Awesome, this should be a sticky. Agreed. Quote
ManicMechanic Posted September 30, 2008 Report Posted September 30, 2008 And you don't really need to drain the coolant much, the miniscule amount that comes out isn't worth it. Quote
oldscsc Posted September 30, 2008 Report Posted September 30, 2008 Glow hurts my eyes when reading for an extended amount of time..................................................................................... Quote
rossg Posted October 5, 2008 Author Report Posted October 5, 2008 I like to clean everything so taking out the rail was no big deal I have the tools so I poped it out. When the rail is out of the car you can also clean your injectors and not have it flopping in your way. you dont have to drain the coolant but it just makes things that much easier when you are in there it is nice to have the coolant drop into a drain pan instead of your driveway. I did the glow so people could see what I was writing I actualy took the pics when I put the motor back together it was really dirty before. the pics are in reverse order. Quote
tdvs Posted October 5, 2008 Report Posted October 5, 2008 Should definitely be a sticky. I'm big on cleaning stuff too, so taking a few extra things off to clean is a good thing. Makes reassembly neater and cleaner. Plus I like the engine compartment as clean as the rest of the car. If you do your own work, you can never have too many tools. You'll need them sooner or later. Tom Quote
alphagtp Posted October 5, 2008 Report Posted October 5, 2008 is not a sticky yet??? I need to do this to mine sometime soon Quote
Pontiac6KSTEAWD Posted October 6, 2008 Report Posted October 6, 2008 Dont forget to replace the Distributor Delete O-Ring while you are there... Quote
rossg Posted October 8, 2008 Author Report Posted October 8, 2008 Dont forget to replace the Distributor Delete O-Ring while you are there... Thanks actualy called an oil pump drive and in order to change it on a 3.4 you need to remove the rear head. that is an awful lot of work. Quote
GP1138 Posted October 8, 2008 Report Posted October 8, 2008 THANK YOU for that picture. I have a much better idea of how to go about half-assing my oil-pump drive seal now. Quote
rossg Posted October 8, 2008 Author Report Posted October 8, 2008 THANK YOU for that picture. I have a much better idea of how to go about half-assing my oil-pump drive seal now. clean it up realy good and put some high temp rtv around it. they were realy easy to change on the 2.8 and 3.1 but i will do my best to never change one again on a 3.4. Quote
9lumina6 Posted October 20, 2008 Report Posted October 20, 2008 THANK YOU for that picture. I have a much better idea of how to go about half-assing my oil-pump drive seal now. Gotta do my o-ring seal BADLY.....My LIM, UIM, and valve cover gaskets are brand new.......but that shaft is spewen oil...........didnt really realize how horribly bad its gotten until today when i was vacuming the car out....and noticed that when driving.... the oil that leaks down blows back onto the floorboard......and somehow, the carpet area behind my driver seat is SOAKED in oil.......and i have never spilled oil inside that car........if i carry new or used oil........it goes in the trunk. THANK YOU for that picture. I have a much better idea of how to go about half-assing my oil-pump drive seal now. clean it up realy good and put some high temp rtv around it. they were realy easy to change on the 2.8 and 3.1 but i will do my best to never change one again on a 3.4. Someone told me that if u pull the shaft out an inch or so........clean it w/ brake parts cleaner... and take an old o-ring seal from a 9007 light bulb....and put it around the shaft....put some silicone around it... set it back down.....and let dry, it should take care of it........the person that told me this did it to his old 92 Z-34 he used to have........and it never leaked a drop after that. I need to do that to mine. Quote
GP1138 Posted October 20, 2008 Report Posted October 20, 2008 THANK YOU for that picture. I have a much better idea of how to go about half-assing my oil-pump drive seal now. clean it up realy good and put some high temp rtv around it. they were realy easy to change on the 2.8 and 3.1 but i will do my best to never change one again on a 3.4. I will probably do all my gaskets and spark plugs before winter comes and I will probably do this then. Quote
webxfx Posted November 6, 2008 Report Posted November 6, 2008 Great picture - that's going to help me fix the oil leak... not sure if I want to do it now or wait till after winter Quote
Go4DaMo Posted October 21, 2009 Report Posted October 21, 2009 I'm going to attempt this ASAP to fix my Z34. Thanks for the info! Quote
rossg Posted October 21, 2009 Author Report Posted October 21, 2009 I'm going to attempt this ASAP to fix my Z34. Thanks for the info! glad to be of help Quote
Go4DaMo Posted March 14, 2010 Report Posted March 14, 2010 Just wanted to note: there are two nuts to remove on the upper plentum, in addition to the 7 bolts. Quote
GTP091 Posted March 15, 2010 Report Posted March 15, 2010 Great picture - that's going to help me fix the oil leak... not sure if I want to do it now or wait till after winter Don't wait it isn't worth tearing up your lifters and causing other damage if it gets to low. I did the brake cleaner, brown o-ring, RTV fix on my engine and it's still dry 5 years later. Quote
GTP091 Posted March 15, 2010 Report Posted March 15, 2010 Just wanted to note: there are two nuts to remove on the upper plentum, in addition to the 7 bolts. It would also be a good idea to stuff clean rags into the ports to keep debris from entering the cylinders while the intake is off. Quote
Red Nightmare Posted January 13, 2011 Report Posted January 13, 2011 The dist shaft cap - It doesn't pull up very much at all. Maybe like 1/8 inch. the best way to clean under it I found was to soak some thick string in solvent/mineral spirits and work it around the thing... tedious cleaning job around there but once you do that then you can re-seal, I just crammed some high-temp RTV under it best I could and spun the cap to work it around, put a bit more in, spun cap, and put the clamp back on. Seems to be holding nicely for now. If you have to pull the heads for whatever other reason night as well fix it properly but the above rig seems to do nicely for a while. Quote
cutty collector Posted October 8, 2016 Report Posted October 8, 2016 If you do want to permanently repair it with the head off use a standard small block distributer base gasket and it will never leak again we used to do it a the gm dealer I worked at whenever we did intake gaskets on 3100 and 3400 engines Imp558 1 Quote
Psych0matt Posted October 8, 2016 Report Posted October 8, 2016 If you do want to permanently repair it with the head off use a standard small block distributer base gasket and it will never leak again we used to do it a the gm dealer I worked at whenever we did intake gaskets on 3100 and 3400 engines I'm pretty sure he didn't wait five years to get started on this project... Imp558 1 Quote
Imp558 Posted October 8, 2016 Report Posted October 8, 2016 You don't KNOW that for sure. Psych0matt and rich_e777 2 Quote
