2003 gm radio fit into a 92 lumina
well i have a new 2003 radio with vcs and info stuff on it. im trying to see if it willwork for my car. I know all the audio wires for speakers but what about a power wire to fire it up. is it possible.
what car is it from? If its a 1.5 din, it should "fit" but would look very out of place in the old Lumi dash. If its the double din (like from a bonnie) it won't fit. Speed Sound and things like that would need to be wired in, as old cars dont have the provisions for that.
so that BCM has a ground that powers it up? because i just cant run the orange wire for it to work like i said only the clock works and it resets when i cut off the car for a bit and turn it back on.
  • 1 month later...
The BCM tells the radio when to turn on. The newer RDS radios do not have a switched power wire because of this.
And yes, as Chris said, you'll need a tech 2 to at least disable the theftlock in the radio.
