My car wants to hurt me :(
Past two days, it has done this three times. My car will randomly start blowing hot air at about mid-fan level out of the vents and the ECC unit will go completely blank(normally displays outside temp and says 'off'). Even if I press the off button, try to turn down the temp or even change which vents it blows through I get nothing. In other words, my climate control goes completely dead and it blows hot air, to which I have no self defence, I just have to take it.
Generally when I turn my car off, then turn it back on, everything goes back to normal. What's wrong, is my ECC done for or is some wiring funky or what?
Thanks for your help guys.
lol my dodge intrapid does the same thing. It is a failsafe that blows heat through all the vents on a #2 speed setting to get you where you have to go but you cannot control anything
Now that you'e fixed the rust on your car, it has no more use for you, it is now trying to cook you and eat you when you least expect it, scary stuff man.
LOL When I read this, all I could picture was you driving down the road with a dejected blank stare on your face as you are getting blasted with hot air. :lol: :lol:
But seriously it does sound like a bad HVAC unit.
is there any possible way to fix them lol. It is such a common problem on the dodges that i dont even want to go and pull one lol
