topless94style Posted August 13, 2003 Report Posted August 13, 2003 So when i bought the car on July 1 it had a small rough idle. As the days went on it got worse. Finally about a week later it would start and die. By the way this was only when the engine was cold like if i went to start it for the first time in the morning or if it had been sitting for 4hrs+. After a week of that i added more oil(o-ring leakage) filled up the tank and dumped in a can of Seafoam into the gas tank AND the crankcase. One can each. After doing so i read the directions and realized i dont need that much in either but i thought oh well cant hurt. It didnt the idle slowly got better and after a few days it was gone. Well about a week ago the idl came back and its gettin worse again. The service engine light is being tripped by something every once in a while mostly if the car has been sitting for more than 8 hrs and goes off after a couple minutes. I thought maybe EGR but that would keep a code all the time right? Then i though 02 and tried to replace but cant get at it so i figured ill look someplace else. Anyone know how to change on 02 on a 3.4L? There is also a rattling noise that comes from the cat more so when the idle is ruff than normal and u also get a stong smell of exhaust/gas mixture. Thats why i think its the 02 cuz it smells like its running rich/lean. I dont know the difference between. Sorry for the length but i know that detail is important. Help is needed thanks. Quote
jeffcanada Posted August 13, 2003 Report Posted August 13, 2003 I'll bet that it is an EGR code (probably 32) that you are throwing. I throw an intermittent one when I decelerate from highway speed, and my idle is a bit crappy too. EGR codes do not have to be 'hard' codes. It could also be a plugged cat and maybe the O2, but I'd bet that it is the EGR. If so, try giving it a clean with TB cleaner and changing the gaskets. Jeff 1992 SP STE 3.4L Quote
patgizz Posted August 13, 2003 Report Posted August 13, 2003 first thing, pull the code, don't just go replacing parts at whim hoping it will work. thats what the check engine light is there for, to tell you whats wrong. Quote
Lancenone Posted August 13, 2003 Report Posted August 13, 2003 Try unplugging the elecrtical connector to your IAC valve while your car is off. Then start it back up and see if it has a rough idle. I unplugged mine and have been driving around without for a day. My idle problems stopped. So I'll have to replace that, I think that's the problem. Anyone know if I'm gunna brake something by driving around with the IAC valve power unplugged? Quote
topless94style Posted August 13, 2003 Author Report Posted August 13, 2003 So i can i pull codes with paper clip on my car even thought its a 94? or do i have to get a code reader or someone that has one. Quote
Slade901 Posted August 14, 2003 Report Posted August 14, 2003 Autozone can get the code for you for free. Quote
topless94style Posted August 14, 2003 Author Report Posted August 14, 2003 So how do i get the code that triggered the service eng light? Quote
Redfox340 Posted August 14, 2003 Report Posted August 14, 2003 So i can i pull codes with paper clip on my car even thought its a 94? or do i have to get a code reader or someone that has one. Try it see what happens. If you pull a code, it works. If not, Slade901 was correct in saying that AutoZone does pull codes for you for free. - Erik Quote
topless94style Posted August 14, 2003 Author Report Posted August 14, 2003 My bad i miss read i thought he said anyone can pull codes thats what i repeated what i said. now i get it! sorry i work overnights and im tired all the time Quote
topless94style Posted August 16, 2003 Author Report Posted August 16, 2003 Its been said my problem could be the O2 sensor. Any tips on replacing this on the 3.4L? I cant seem to get at the bastard. Quote
Redfox340 Posted August 17, 2003 Report Posted August 17, 2003 Its been said my problem could be the O2 sensor. Any tips on replacing this on the 3.4L? I cant seem to get at the bastard. Either from underneath the car or you'll need to pull the exhaust manifold. - Erik Quote
Slade901 Posted August 17, 2003 Report Posted August 17, 2003 Note: Because the oxygen sensor is installed in the exhaust manifold or pipe, which contracts when cool, the oxygen sensor may be very difficult to loosen when the engine is cold. Rather than risk damage to the sensor (assuming you're planning to reuse it or perhaps just cleaning it), start and run the engine for a minute or two, then shut it off. Be careful not to burn yourself during the following procedure. I recommend using an oxygen sensor socket tool. Can't you not rotate the engine forward to get easier access to the oxygen sensor? Quote
Redfox340 Posted August 17, 2003 Report Posted August 17, 2003 Can't you not rotate the engine forward to get easier access to the oxygen sensor? On a DOHC, it's possible but still there are issues with space / clearance. Any way, or any shot you've got is a good one... extra room is a plus when working on the LQ1. - Erik Quote
topless94style Posted August 17, 2003 Author Report Posted August 17, 2003 I thought about rockin the engine forward but i still cant get at it from the top. Underneath its hard to get a wrench on the damn thing because it sits on top of the exhaust pipe that is directly connected to the exhaust manifold if i remember correctly. And there is some stupid piece of metal sticking up right next to the sensor that will everyonce in a while get the wrench caught up adn just when i think im gonna put tons of pressure on the sensor it snaps loose i scrap my knuckles and scream obsenities. Ill prolly have to remove the exhaust pipe from the manifold and see where i get from there. Quote
Slade901 Posted August 17, 2003 Report Posted August 17, 2003 Are you using this? You would need a long extension bar http://imagehost.vendio.com/bin/imageserver.x/00000000/parkersales/Extbar12.jpg and universal joints http://ebay2.ipixmedia.com/abc/M28/_EBAY_688f415e44950527e75f1e37e9737a38/i-1.JPG I would use a 1/2" ratchet to get more leverage or a 1/2" breaker bar. Quote
