jmoore4294 Posted September 24, 2008 Report Posted September 24, 2008 So lately my idle has been acting up. On a cold start or really any start, the RPM shoots to 2k and sits there for about 5 sec. As soon as the idle smooths out to 1k, it is very erratic sputtering from 500 to 1k. Every now and then I get a smooth non erratic idle. But that only happens once every full moon. It is due for a tune up. Guess I'll start there. Anything I should pay extra attention to? So far I have plugs, wires, fuel and air filter, possibly coils, IAC valve, pcv valve. Also, from your guys' experience, what would be the easiest way to get to the rear spark plugs? Quote
Andrew Posted September 25, 2008 Report Posted September 25, 2008 i would ohm out the injectors and make sure they are all kosher. you'll need to pull the plenum to do so on the rear injectors. with that removed, it is also the time to replace the rear plugs. remove the dogbone and rock the engine forward a little bit to give a little more clearance to the rear. Quote
jmoore4294 Posted September 25, 2008 Author Report Posted September 25, 2008 Just remove the plenum? Shouldn't be hard. What ohm rating is considered normal for the injectors? Quote
ManicMechanic Posted September 25, 2008 Report Posted September 25, 2008 I can remove the plenum on my 3.4 in less than 10 minutes...LOL! Sounds like what mine is doing as well and it's had a full tune up. I'm going to ohm the injectors tomorrow or the weekend and see if that's the problem. Quote
swift13 Posted September 25, 2008 Report Posted September 25, 2008 check your tps and maf but if theres no light they should be good i have the same prob i think with my 3.4 as i have mentioned on here before next thing for me is the cat. i have done about everything else Quote
ManicMechanic Posted September 25, 2008 Report Posted September 25, 2008 I can remove the plenum on my 3.4 in less than 10 minutes...LOL! Sounds like what mine is doing as well and it's had a full tune up. I'm going to ohm the injectors tomorrow or the weekend and see if that's the problem. Well hell...They're all at 12.7-12.9. The plenum reeks of gas...Perhaps my FPR went bad? Quote
95 vert Posted September 26, 2008 Report Posted September 26, 2008 I've found on several occasions the idle problems usually end up being a vacuum leak and/or leak between the MAF and throttle body. Quote
