carkhz316 Posted February 16, 2009 Report Posted February 16, 2009 Well will continue this saga, and once I have done everything, I will make a new How-To write up thread that better damn well be stickied!! YES. Please do good sir!!!! Quote
19Cutlass94 Posted February 16, 2009 Report Posted February 16, 2009 Did you guys have to hone out the sleeves at all? Quote
alphagtp Posted February 16, 2009 Report Posted February 16, 2009 dumb question, but, would this "allow" you to adjust the height of the rear?? Quote
CSI_MuNkY Posted February 16, 2009 Report Posted February 16, 2009 Did you guys have to hone out the sleeves at all? I have to hone out my new sleeves. I will be doing this in the next couple weeks in class on a lathe with a boring bar. Jamie Quote
GOT2B GM Posted February 16, 2009 Report Posted February 16, 2009 did you ask your teacher if they have one? Quote
BXX Posted February 16, 2009 Author Report Posted February 16, 2009 i used coilover sleeves from a1racing no honing required http://shop.a1racing.com/cok12457-tk.aspx they also carry this one now which should work on Gabriel and Monroe struts which are just barely to big for the sleeve that fits the smaller kybs http://shop.a1racing.com/cok12452-h.aspx Quote
19Cutlass94 Posted February 16, 2009 Report Posted February 16, 2009 Those are the same sleeves I have and I had to hone them out. Quote
BXX Posted February 17, 2009 Author Report Posted February 17, 2009 They worked great for me.... My adjuster nuts and sleeves came in today, I didnt get back into town until an hour ago so they were delivered to out leasing office. I will get them tomorrow and test fit them on the spare front knuckles I have, and I only have 2 more items to come in and then everything goes on the car. I will update yall Quote
BXX Posted February 17, 2009 Author Report Posted February 17, 2009 Picked up the adjuster nuts and sleeves from our leasing office. Waiting on the torrington bearings and upper spring seat. About to go pick up the ES Poly inner sway bar bushings for my FE3 bar I ordered from Autozone. Hopefully the spring seats will arrive today. Once again, the stock mount will be implemented until I get ones made that I want. Gonna have my father draft them up on Solid Works once I get him some measurements. Hopefully, everything comes today so I can get my car on the lift at work tomorrow and get everything done. Fuckin cradles gonna tie up everything most of the time. Calls for 4.5 hours, I hope to have it done in under 2. What will be getting done -Removing rear springs, going to the front, install new springs on the rear -Install 22mm ES Poly bushings on the rear sway bar -Install new front cradle, with TGP rack on it, and FE3 bar with ES Poly bushings -Tear down front knuckles, modify for coilovers -Install FE3 front upper stock mounts -Install front coilovers -Set ride height, as low as possible, checking for rubbing. -Align car, I expect to have to do full camber adjustment front and rear to coincide with my specs _EDIT_ UPS just dropped off my torrington bearings, looks like I have to wait another day for my upper spring seats... Quote
Venom Posted February 18, 2009 Report Posted February 18, 2009 Cant wait for you to be done so I can copy you LOL. Cant wait to get to the yard to pick up some rear suspension parts. Quote
gpchris Posted February 18, 2009 Report Posted February 18, 2009 what ID size did you use for the sleeves on the front? Quote
CSI_MuNkY Posted February 18, 2009 Report Posted February 18, 2009 what ID size did you use for the sleeves on the front? Same as the rear works Jamie Quote
gpchris Posted February 18, 2009 Report Posted February 18, 2009 what ID size did you use for the sleeves on the front? Same as the rear works Jamie really? so the front and rear struts have the same OD? Quote
CSI_MuNkY Posted February 18, 2009 Report Posted February 18, 2009 what ID size did you use for the sleeves on the front? Same as the rear works Jamie really? so the front and rear struts have the same OD? Indeed they do... I know this because when got the helds I almost put the rear sleeves on the front and the fronts on the rear... only problem would of been setting at stock ride height. Held sells his with a spacer to move the rear sleeve up 2 inches, but his sleeves are only 5 inches. I just finished machining out some sleeves from Summit Racing, I had to take a total of 100 thou of the total ID, but now they fit... I will post about that later... Jamie Quote
gpchris Posted February 18, 2009 Report Posted February 18, 2009 what ID size did you use for the sleeves on the front? Same as the rear works Jamie really? so the front and rear struts have the same OD? Indeed they do... I know this because when got the helds I almost put the rear sleeves on the front and the fronts on the rear... only problem would of been setting at stock ride height. Held sells his with a spacer to move the rear sleeve up 2 inches, but his sleeves are only 5 inches. I just finished machining out some sleeves from Summit Racing, I had to take a total of 100 thou of the total ID, but now they fit... I will post about that later... Jamie Cool so what ID will I need? Im going to be buying sleeves as soon as i know for sure. Quote
BXX Posted February 18, 2009 Author Report Posted February 18, 2009 Update guys!!!!! I have everything in now. Only one problem, sleeves are indeed wrong. Heres why When I placed an order to do the rears last year, the sleeves I got were on backorder, a1racing called me, and after talking to him, he knew I ordered the wrong sleeves since he supplies the sleeves to Lee at Held! He shipped me sleeves I needed that were 2.171" ID, not the 2.100" that I ordered. My online order didnt reflect the different sleeves he shipped me, so when I just placed my last order, I got the wrong sleeves. Didnt catch it until earlier today. I just got off the phone with a1racing, the correct sleeves are now on order, I will get them Monday. They dont have the 7" long 2.171"ID anymore, they only have 5" which will work fine since my goal is to lowered, not lifted So the PN I just posted was incorrect, I will update with new correct numbers on everything. Oh yeah, Gen 2 front mounts are needed for everything to work correctly without being halfassed. I will take pics and post them soon Quote
CSI_MuNkY Posted February 18, 2009 Report Posted February 18, 2009 http://www.w-body.com/forum/index.php?topic=61157.msg1019370#msg1019370 Rather than crowd 1loudcutty's thread with an update on my suspension I bumped my old thread... Jamie Quote
BXX Posted February 18, 2009 Author Report Posted February 18, 2009 PARTS NEEDED FOR FRONT COILOVER CONVERSION!!!!! http://www.a1racing.com Coilover Sleeves - COK12452-H Coilover Adjuster Nuts - COK12460 Upper Spring Seats - COK12470 http://www.resuspension.com Coilover Bearing Kit - RE-KT-BRG-2.5 http://www.summitracing.com 2.5"ID Coilover Spring - HAL-12-(insert spring rate here, i.e. HAL-12-300) http://www.autozone.com Gen 2 Upper Strut Mount - 142526 LINKS http://www.resuspension.com/KIT-C-O-BEARING-ASSY-2500-ID-p-15411.html http://shop.a1racing.com/cok12452-h.aspx http://shop.a1racing.com/cok12460.aspx http://shop.a1racing.com/cok12470.aspx http://store.summitracing.com/egnsearch.asp?N=700+4294925130+4294846689+4294791365+4294787535+400026+115+4294868436 http://www.autozone.com/R,1510459/vehicleId,2396103/initialAction,partProductDetail/store,1740/partType,01047/shopping/partProductDetail.htm Quote
CSI_MuNkY Posted February 18, 2009 Report Posted February 18, 2009 Any pics of what your doing to the upper spring mount? Jamie Quote
BXX Posted February 18, 2009 Author Report Posted February 18, 2009 Any pics of what your doing to the upper spring mount? Jamie Gimme a few minutes dammit :lol: I gotta bust out my camera and take pics... Quote
CSI_MuNkY Posted February 18, 2009 Report Posted February 18, 2009 lol I ALWAYS have a camera at my disposal... Cell phone, my old point and shoot and now the SLR Jamie Quote
BXX Posted February 18, 2009 Author Report Posted February 18, 2009 lol I ALWAYS have a camera at my disposal... Cell phone, my old point and shoot and now the SLR Jamie yeah, im downloading pics from my camera now, and then gotta upload them to photobucket gimme 20 minutes. I aways have a camera too now, either my good digi or my cell phone. Quote
BXX Posted February 18, 2009 Author Report Posted February 18, 2009 Uploading pics now, this may take a few I dont have a desktop anymore, so Im having to use my Tablet PC.. A bit slow on memory intensive apps. Quote
