GTP Didn't pass inspection
Ok took the gtp in for a state inspection. and it Did not pass
Needs
Power steering rack
Front tires (have NO idea why)
Stabalizer links (both broke on front) (Both sides)
so how hard is the power steering rack going to be to replace. and WTF are Stabalizer links
  • Replies 55
  • Created
  • Last Reply
Top Posters In This Topic
  • Addicted to eaton
    7
  • 1990lumina
    5
  • 5speedz34
    3
  • mra32
    3
Sway bar end links.You have to drop the subframe to get the power steering rack out, about a half day job.They want pass you for worn tires.
Must be too many stupid burnouts.
If your not going to do the rack yourself, expect to pay a damn good amount of money.
End links are a cake job.
my dad said he would the the rack. Burnouts.. are not much in this car. I dont wanna rip the tranny out.
yeah thats whats wrong with the frint tires.. tread on the inside is less the on the outside.
I showed up to my inspection (in the escort) with a blow-out, a crapload of rust, a rear swaybar that wasn't connected on the drivers side, and a parking brake that doesn't work.... Ten minutes later I was out of there with a freshly aired up tire and a inspection sticker!! :mrgreen: :mrgreen: :mrgreen:
Yep, here they don't care or look hardly at all. They walk around the vehicle once, looking for obvious defects. Then, they take the VIN number down. The last thing they do is look under the hood, but I don't think they have a clue what they're looking at.
That's only for out of state inspections though. You can drive a truck that's been out to pasture for 20 years on the street with no inspection if it's got a Kansas title :mrgreen:
Our inspections are pretty strict...But I know someone with a 240SX that you can literally see the front fender while driving directly behind it and has bald tires but yet it passed.
I love our lack of inspections in OH.
Want another Cutlass, Anthony? It'd pass inspection, I think. Unless a bad driver window motor is a safety issue. :D
Failure to open the drivers side window is a big no no in north carolina. They say if you can't open the window for hand signals, then it's a safety issue and you won't pass.
Mo. inspection covers alot of shit. Lights,horn,glass,fluid leaks(p/s, brake) and level,tires,brake pad thickness,mirrors,tie rods,ball joints,links,etc. The tires can look like shit but cannot show cord or be worn to the depth markers across three treads. Obviously you found a guy that thought he might make some extra cash on repairs. Most inspectors don't look that closely at p/s leaks.
Fucking GM and their sway end links lol...EVERY GM used car that goes through my shop gets a pair of end links put on. Cobalts with 20k on them had play in the end links already lol
Nothing in MN. Pretty easy to drive with any condition exhaust or anything for that matter! :flipa: :willynilly:
Wow, I'm so lucky to live where I do, right here in Lincoln, Nebraska. They don't do any inspections here, meaning that I can get away with a lot here. :nana:
That is how Minnesota is too, no vehicle inspections of any kind.
Im in Omaha, NE. Its pretty much free game.
Worn tires are a safety issue.
That's what I find hilarious about where I live, you can fail an emissions test for having a locking gas cap that leaks a little air, but you can't fail for having a gas tank that has a massive hole in it, or tires that are worn right through to the tread.
Will end links stop the tire wear problem? Tire wear is usual the cause of suspension problems. So replacing the tires is irrelevent if you don't fix the problem at the source, unless they just weren't balanced right on the way on.
don't forget to look at springs, tie rod ends and ball joints :willynilly: while you doing the rack. & after the rack is r&r you need aligned anyways :high5: also get a 4 wheel alignment it worth it. also if you can replace the upper rear strut bolt with a adjustable one's it make's it much easier to set up the rear. there cheap at http://www.partsamerica.com
The sway end links just provide the mounting point for the sway bar, does nothing for alignment.
