oldscsc Posted November 17, 2008 Report Posted November 17, 2008 Actually, for the 3100/3400, the PCM's between '96 and '97 physically look identical. Even the harnesses can be interchanged. It's just an internal memory difference. '97 has 512kb while '96 has 256kb. For example, I'm running a '97 Lumina harness and I had a '96 Venture PCM in there for a while. I'm now running a '97 3800 PCM with a 3400 file flashed into it. The only difference *I* found between a '96 and '97 w-body harness is the cruise control circuit. However, the end result is they both work the same. Just the fuse location and some wiring got moved around. I thought the first year for the Venture was '97? Quote
Brian P Posted November 17, 2008 Report Posted November 17, 2008 Actually, for the 3100/3400, the PCM's between '96 and '97 physically look identical. Even the harnesses can be interchanged. It's just an internal memory difference. '97 has 512kb while '96 has 256kb. For example, I'm running a '97 Lumina harness and I had a '96 Venture PCM in there for a while. I'm now running a '97 3800 PCM with a 3400 file flashed into it. The only difference *I* found between a '96 and '97 w-body harness is the cruise control circuit. However, the end result is they both work the same. Just the fuse location and some wiring got moved around. I thought the first year for the Venture was '97? Ah right. '96 would be the Lumina APV. Same thing applies to the engine management system though. Quote
ismellrealbad Posted November 17, 2008 Report Posted November 17, 2008 Ok.... This was my 96 PCM So you're saying the venture pcm youre talking about is this? and both will plug into the gen1 obd2 3100 harness Quote
Brian P Posted November 17, 2008 Report Posted November 17, 2008 The W-body and U-Van PCM *3100/3400* from '96-97 looks exactly like your 1st picture, and yes, it will plug into *3100/3400* '96-97 W-body PCM's *edited for clarity Quote
ismellrealbad Posted November 17, 2008 Report Posted November 17, 2008 perfect. thank you. now who do you know can do a tune and for how much? Quote
Brian P Posted November 17, 2008 Report Posted November 17, 2008 In all reality, you COULD temporarily run your original 3100 PCM on the 3400. Then either have a '96 Lumina PCM file flashed onto it, OR get a '97 Venture PCM when you get the chance. Matter of fact, I might still have my '96 3400 PCM somewhere if you're in a bind and need it. Quote
ismellrealbad Posted November 17, 2008 Report Posted November 17, 2008 no, thanks to my japanese wonder blowing the diff i now have to put a trans in it so this wont be happening for a month or so. when i actually get the motor in if i have trouble finding one i might take u up on that. just tryin to do my homework now incase a good deal or find comes along. Quote
Brian P Posted November 17, 2008 Report Posted November 17, 2008 perfect. thank you. now who do you know can do a tune and for how much? I don't know anyone local other than myself. If you get everything installed and going, I may still have the stock '96 Lumina APV 3400 file on my tuning laptop. I have been considering selling my DHP Powertuner which is unlocked for all 3100/3400 cars. But if nothing else, maybe once it's installed and running we could meet up and we'll work something out. As a minimum though you could definetly run and drive the 3400 with your original computer and harness. The swap is amazingly easy on '96+ cars. Quote
ismellrealbad Posted November 17, 2008 Report Posted November 17, 2008 easy is what im going for. im tired of this 3800 bullshit. i miss my car and i decided if even if its way slower ill take what i can get. itll still be uber fun now that its stick. Oh and i bet my exhaust will sound wayyyy better with a 60* Quote
Brian P Posted November 17, 2008 Report Posted November 17, 2008 Oh that's right, you're not going back to the automatic Yeah you'd end up needing some tuning but even so, you'll get her on the road. You could always do some basic modifications- 2.5" downpipe, camshaft and other things from the 60* store if you'd want. Downpipe is definitely the easiest and it does make a difference. Quote
ismellrealbad Posted November 17, 2008 Report Posted November 17, 2008 i need one anyway. i still have a 3800 dp. yeah it should run fin but with a MIL. Ill want to get rid of that tho asap Quote
ismellrealbad Posted November 18, 2008 Report Posted November 18, 2008 What was the link to the 60* store? i putzed around briefly but failed at finding Quote
jimmyfloyd Posted November 18, 2008 Report Posted November 18, 2008 Ok, so you need a engine harness from a 96 or 97 W-body, and the PCM from a 96/97 Lumina/Venture, correct? Will any wiring have to be run inside the car for OBD2, or is it plug and play? Quote
ismellrealbad Posted November 18, 2008 Report Posted November 18, 2008 Parts I specifically will need: -1996 3100 Grand Prix harness -20xx W-body 3400 (for bolt in ease) -3400 DP -1997 Venture/Montana 3400 PCM -2.8/3.1 5 speed flywheel (after looking at my 3800 flywheel it seems it may fit. Im going to see if it does) Quote
ismellrealbad Posted November 18, 2008 Report Posted November 18, 2008 http://wot-tech.com/shop/ Thats the site i found. in the sidebar it lists 60 parts. when you click it only has one pagefull of parts and i do not see a DP. WTF Quote
Brian P Posted November 18, 2008 Report Posted November 18, 2008 they don't have downpipes. I had to have a local shop fab one up. Quote
IRONDOG442 Posted November 19, 2008 Report Posted November 19, 2008 What does your Cutlass run Brian ? Quote
Brian P Posted November 19, 2008 Report Posted November 19, 2008 I dunno, I haven't taken it to the track. I have a Gtech, and last time I used it (like a year ago) it was good for low 15's at around 95 MPH. I take Gtech numbers with a grain of salt though. With the stock 3100, it ran 16.8@ I believe 88 MPH. The motor will be "finished" by spring time, that's when I'll take it to the track. Quote
ismellrealbad Posted November 19, 2008 Report Posted November 19, 2008 16.8 sounds about right for a 3100. low 15s at 95??? thats all top end right there. the L67 was 14.4 @ 95 with a 2.1 60' Quote
Brian P Posted November 19, 2008 Report Posted November 19, 2008 16.8 sounds about right for a 3100. low 15s at 95??? thats all top end right there. the L67 was 14.4 @ 95 with a 2.1 60' Yeah the cam I have gives bias towards the top end. Not really what I wanted to have, but the larger TB and 3500 intake gave me back a lot of low end power. Gtech also likes to be optimistic with trap speed. It's probably more like 92-93mph but I won't know until I take it to a real track. I should run a Gtech tonight just for comparison's sake. I think it's in the trunk of my car all these years Quote
ismellrealbad Posted November 19, 2008 Report Posted November 19, 2008 break that bitch out. maybe take a vid Quote
Brian P Posted November 19, 2008 Report Posted November 19, 2008 perhaps. I might have my camera tonight. Quote
