Quaraxkad Posted September 20, 2008 Report Share Posted September 20, 2008 I'm replacing some wiring in my 92 Cutlass. The injector fuse is blowing and I've found a LOT of bare/exposed wire on the injector harness so it's probably shorting out somewhere. One of the wires I need to replace is the one connected to the fuse box under the hood. The wire had almost NO insulation left on it, all the way up to the terminal that the fuse plugs into. Obviously there's no way I can splice a new wire into that since it's stripped all the way up the terminal. Where can I get some of these terminals that I can crimp a new wire into? Quote Link to comment Share on other sites More sharing options...
ismellrealbad Posted September 20, 2008 Report Share Posted September 20, 2008 dealer possibly Quote Link to comment Share on other sites More sharing options...
Crazy K Posted September 20, 2008 Report Share Posted September 20, 2008 WOW! that wire looks like it got shorted and melted all the insulation off. You could go to a j/y and salvage all the wiring you need to fix it. Quote Link to comment Share on other sites More sharing options...
Quaraxkad Posted September 20, 2008 Author Report Share Posted September 20, 2008 WOW! that wire looks like it got shorted and melted all the insulation off. That pink/black wire has melted insulation every few inches, it's almost certainly the reason my INJ fuse is blowing. But now I need to find out if it's the cause of the problem or a symptom of something else... I checked the resistance of all the injectors and they were all perfect, what else could it be? Quote Link to comment Share on other sites More sharing options...
Crazy K Posted September 20, 2008 Report Share Posted September 20, 2008 unsure. start with replacing all the damaged wires... and check ALL FUSES in your car to make sure they are the proper amperage. You probably don't even realize the number of cars that I've looked at that people have incorrect amperage fuses in. Quote Link to comment Share on other sites More sharing options...
Venom Posted September 20, 2008 Report Share Posted September 20, 2008 I would say go to the J/Y and snip the length you need. Then pocket it and walk out LOL. Quote Link to comment Share on other sites More sharing options...
