dirt_igirt Posted September 19, 2008 Report Posted September 19, 2008 so i went to go to work today and i pulled out of the drive way and got like 1/2 mile down the road and the engine just started knocking really bad so i babyed it to the shop my buddy works at and hes gonna look at it tomorrow so the gp might be getting parked for a while til i find the tgp engine. so she might be getting all torn apart this winter if i stay in michigan Quote
Andrew Posted September 19, 2008 Report Posted September 19, 2008 if it happened all randomly, i would think there is a sudden shortage of oil. replace your oil filter, when they fail they block off oil pretty well. Quote
dohc v6 Posted September 19, 2008 Report Posted September 19, 2008 Another one bites the dust. I love it when my motors blow up, then I get to build them to my standards not GM. If you need help man, you know where to holla. Quote
rockfangd Posted September 21, 2008 Report Posted September 21, 2008 Independentfool said: if it happened all randomly, i would think there is a sudden shortage of oil. replace your oil filter, when they fail they block off oil pretty well. x2 usually if the engine is going to knock it will do it when it is cold and first started. Do you have an oil pressure gauge? Quote
Andrew Posted September 21, 2008 Report Posted September 21, 2008 please, before you buy another motor, try fixing the simple stuff. and if you are looking for a simple swap, get another 3.1. Quote
ismellrealbad Posted September 22, 2008 Report Posted September 22, 2008 rod knock: any or all of - knocking at idle/light load med to high rpm/on decel main bearing/piston pin/piston: generally at all times cam bearing/valvetrain: knocking or noise at double the speed of crank rotation (use timing light) Quote
89SupremeCutty Posted September 23, 2008 Report Posted September 23, 2008 rockfangd said: Independentfool said: if it happened all randomly, i would think there is a sudden shortage of oil. replace your oil filter, when they fail they block off oil pretty well. x2 usually if the engine is going to knock it will do it when it is cold and first started. Do you have an oil pressure gauge? a knock on an engine when it's cold and first started might not be a shortage of oil. it could also mean that it's piston slap. Quote
rockfangd Posted September 24, 2008 Report Posted September 24, 2008 89SupremeCutty said: rockfangd said: Independentfool said: if it happened all randomly, i would think there is a sudden shortage of oil. replace your oil filter, when they fail they block off oil pretty well. x2 usually if the engine is going to knock it will do it when it is cold and first started. Do you have an oil pressure gauge? a knock on an engine when it's cold and first started might not be a shortage of oil. it could also mean that it's piston slap. well everyone should know the difference between piston slap and a rod knock. I have never seen one that did not have piston slap lol Quote
Euro Posted September 24, 2008 Report Posted September 24, 2008 rockfangd said: 89SupremeCutty said: rockfangd said: Independentfool said: if it happened all randomly, i would think there is a sudden shortage of oil. replace your oil filter, when they fail they block off oil pretty well. x2 usually if the engine is going to knock it will do it when it is cold and first started. Do you have an oil pressure gauge? a knock on an engine when it's cold and first started might not be a shortage of oil. it could also mean that it's piston slap. well everyone should know the difference between piston slap and a rod knock. I have never seen one that did not have piston slap lol There is a DEFINITE difference between rod knock and simple piston slap....coming from first hand experience. Quote
94slutlasssupreme Posted September 25, 2008 Report Posted September 25, 2008 ok i must say this have your mechanic check for collapsed lifters and i only say that because im doing that now after just rebuilding the top end (my own dumb ass fault for not cleaning them in the first place) and it only took a week and a half for them to go..... oh and you might wanna check your oil pressure Quote
